Old 05-02-2011, 12:41 AM   #1
jowintt01
jowintt01 is on a distinguished road
Default 7mgte ECU
Quick ?.Are ECUs year specific, I bought a 7mgte JDM motor and the ecu was damaged,when I got the replacement I noticed the part numbers were different,I put in in and I can't get the motor to run right.
jowintt01 is offline   Reply With Quote
Old 05-02-2011, 01:44 AM   #2
jowintt01
Default 7mgte ecu
What? No one???
Old 05-02-2011, 05:08 PM   #3
graywolf1969
graywolf1969 is on a distinguished road
Default hey
I did the jdm swap and my car runs very good you have to swap your wiring harness from your old 7mgte and just hook the old ecu up, the one your car came with , the wiring harness that came with my jdm was diffent so i had to swap the wiring harness and the throttel body and the planum thats all i did if you need help on this i have pic on how to do it.
graywolf1969 is offline   Reply With Quote
Old 05-02-2011, 08:39 PM   #4
jowintt01
I had an N/A in the car so it was a non turbo to a turbo it's just that is the ECU year specific?that is 89 motor 89 ECU?I noticed the part numbers are different,even though they are both for 7mgte motors
Old 05-04-2011, 02:52 AM   #5
graywolf1969
ok man try this first go to your car bc mine did this after i put the engine in, The alarm on your car can make your car not start put your key in the door and lock it and unlock it do this like 5 times and then try to start it, o and are you useing the wireing harness that came with the jdm 7mgte
Old 05-06-2011, 08:01 PM   #6
graywolf1969
Default ecu
Ok man you need to go to a junkyard and get a ecu from a supra thats a turbo and its the same yr as your car and how many rpm does your supra have like right on the red line i have one of the 89 yrs that has 6500 rpm
7mgte front clip supraman121 MKIII Supra 4 05-31-2007 01:27 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
7mge to 7mgte kallmijonx2 MKIII Supra 2 10-22-2006 12:55 PM
