#1 |
I have a similar noise coming from my 1jz it's not quite as loud but just as annoying don't know what it is.
#2 |
i found my noise not saying yours is the same but i have a bad head. before i bolted it to the block it sat outside for a few months and the cam bearings got rusted but when i felt the cams they spun fine after running for about 5 minutes the cam bearings were completely gone and now i have a "cam knock"
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rod Knock! OR is IT? | Rob1 | MKIII Supra | 5 | 03-02-2011 12:26 AM |
| Valve Head Noise LOUD TAPPING | batmmannn | MKIII Supra | 28 | 11-13-2010 02:13 AM |
| Bypass Valve Venting To Atmosphere? | Minymurf | MKIII Supra | 4 | 10-04-2010 04:40 AM |
| 87 Turbo knock sensor issue | supraman7 | MKIII Supra | 5 | 03-05-2010 07:44 PM |
| Starting isssues and spark knock Q's | spudz29212MKIII | MKIII Supra | 65 | 05-30-2008 06:44 PM |
