Old 04-24-2011, 08:22 AM   #1
Cyberguy1992
Cyberguy1992's Avatar
Cyberguy1992 is on a distinguished road
Default HAC sensor wiring diagram.. HELP plz..
I think they only put this HAC(High altitude sensor) in 86 and 87 supras with the 7MGTE engine... I had to send new wires from my throttle body strait to the ECU and it still hasn't been running right. Now I just found out that the HAC sensor gets an input from the throttle sensor. I know that what ever that wir is it's not hooked up now.
So what I need is a wiring diagram for this HAC sensor.
Cyberguy1992 is offline   Reply With Quote
Old 04-24-2011, 06:48 PM   #2
The GTE wasn't available in any '86 models (not in any '86.5 models either ). The HAC is present in ALL KVAFM equipped 7M's, it's just been moved inside the ECU on later models. You need a TSRM or TEWD from '87 or '88. Below you'll find links for '87. It has the TSRM wiring diagrams (Not as pretty, but they work).
http://www.turboninjas.com/mk3supra/
I don't recall the HAC getting a THA signal at all. The HAC is a little black box mounted on the back side of the lower glove box support. It's nothing more than a MAP sensor.
I sold all my pre89 manuals some time ago as I seldom needed them for anything which isn't covered in the '89.
Old 04-24-2011, 07:49 PM   #3
Cyberguy1992
Default Worried about V or VC
The HAC dosn't get THA, i'm worried about V.. I'm guessing that V is the same as VC.
Is there any thing else that goes on VC?
The EFI TSRM doesn't show what wires specifically go to the HAC sensor I know E2 is the ground for all sensors but V doesn't even show up on the ECU pin out that I have.
I put this Diagram together and this is my guess. The second diagram (with only the HAC sensor) Came strait from the manual... Just to show that somthing from the HAC does hook in with the throttle sensor and the Air Flow Meter..
Name:	HAC-Air Flow-TPS.jpg
ID:	3906   Click image for larger version
Old 04-24-2011, 08:02 PM   #4
Vc is just a constant voltage signal provided by the ECU to certain sensors... it's a power supply line for lower power devices. Should be around 4.8v with load.
Old 04-24-2011, 08:12 PM   #5
Cyberguy1992
Default Thx
Okay... that makes sense for the HAC to need a negative and a positive to come up with its signal...
Thanx
Old 04-24-2011, 08:23 PM   #6
Are you trying to troubleshoot it or bypass it?
EDIT: If you're looking to bypass it, here's my site with info on MAFT Pro installations and as such info on bypassing the HAC sensor: http://www.fadingworld.com/CRE/Autom...ra/Electrical/ See the GTE install wiring diagram for SD. It's quite easy but for most it's easier to see it than just read it.
Old 04-24-2011, 08:54 PM   #7
Cyberguy1992
I'm going to make a new engine harness and I'm just trying to gather a diagram for the '87.. do the newer ECU pin outs have the same exact names as the one for the '87 and they are just arranged differently?
Old 04-24-2011, 10:00 PM   #8
Look at the diagrams on my site for the '87 - '88 pinouts and cygnusx1 for the '89 - '90. Most are similarly named.... I usually buy an old harness and replace the wires one at a time. Have fun, it sucks!
Tags
hac, hac sensor
1987 Supra wire diagram scrid MKIII Supra 4 04-24-2011 05:42 PM
Wiring diagram? dannydavi MKIII Supra 3 04-07-2009 04:18 AM
Diagram or photos how to get interior panel off? stanley2001 Exterior , Interior, and Detailing 1 08-20-2007 03:44 PM
HLP - 87 fog light diagram kaves_420 Non-Generation Specific Questions 1 10-28-2006 04:49 PM
Vaccum diagram??? h8z2luze MKIII Supra 5 08-11-2006 02:47 AM
