Old 04-22-2011, 05:33 AM   #1
watapinoy
watapinoy is on a distinguished road
Default clutch and transmission
i have a 1989 supra my clutch goes down but wont come back up and it wont let me switch gears. what can be the problem?
watapinoy is offline   Reply With Quote
Old 04-22-2011, 05:44 AM   #2
It would help if you posted in the correct section.
As for your problem... you've either got a leaking master cylinder or slave cylinder or the hose between the two. Check the reservoir, if it's empty, find the leak and replace the bad part. Nothing serious.
Old 04-22-2011, 05:50 AM   #3
watapinoy
i just replaced my master cylinder and slave cylinder the other day worked for 2-3 days then broke on me again.
Old 04-22-2011, 08:36 AM   #4
87hilux7mge
87hilux7mge's Avatar
hmm. lemon parts? where did you get em and did you use thread sealer or teflon tape on all the connections?
ive had soft clutch line hose have an internal hernia, couldnt see it from the outside. also had the slave go bad and just pump fluid into the boot at the end and it didnt show till it blew up lol. that was a fun mess.
Transmission rant, help! Need advice or anything, asap ochowdero MKIII Supra 117 04-11-2011 10:49 PM
transmission? clutch?? mkiii<3 MKIII Supra 7 10-03-2010 09:13 AM
