Old 04-21-2011, 09:43 PM   #1
Travdub666
Travdub666 is on a distinguished road
Unhappy 87 7MGTE running awful!
Ok so I bought my supra 3 years ago it was just a rolling chasis with a donner car. I did a motor swap put in a 5 speed trans with a stage 3 clutch and threw in some interior. I drove it last year when all of a sudden it quit running and wouldn't start up again. Well I figured out that it was the timing pulley it was never tight ( not my fault but I should have checked it.) 1st-3rd gear the car runs pretty decent but 4th and 5th seem like it's has no power and I can just hear my bov sound like it's open all the way. Driving it yesterday it was skipping and bucking like crazy. Any help would be great I'm kinda at a stand still. Another thing is when I fixed the timing I put it at top dead center but I think it's supposed to be 12 deg ahead? Would this make the problem? PLEASE HELP!
Travdub666 is offline   Reply With Quote
Old 04-21-2011, 10:31 PM   #2
Well, have you tested the BOV? If you don't know how then just pull, plug the openings and go for a drive. One drive isn't going to kill anything that's not already 99% shot. If the BOV is leaking then you're overworking the turbo and pushing air that a lot hotter than it should be into the engine.
It's 10 degrees BTDC on the timing (and don't forget the jumper).
Old 05-05-2011, 01:07 AM   #3
Travdub666
Lightbulb
Ok so I replaced the valve cover gasket and replaced the plugs it ran much better but still has a boost problem. So today I read on other post about boosting issues I tightened up all the intercooler and intake hoses I thought but still ran bad. So later I felt under the turbo and the pipe is ripped right off about to change it now so wish me luck!!
Old 05-05-2011, 04:49 AM   #4
Travdub666
Talking
THAT WAS IT!!!!!!!!! SLEEPING BEAUTY HAS RISEN FROM HER SLUMBER AFTER 3 YEARS!!!!!!!!! THANK YOU SUPRA FORUMS!!!!!!!! THANK YOU A MILLION TIMES OVER!!!!!! It's boosting perfect and it's fast as h?||!!!!!!!!!!
Tags
88 supra, running bad
7mgte to 7mge conversion help wayzhack MKIII Supra 7 09-07-2010 08:22 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
