Old 04-18-2011, 12:00 AM   #1
mirage83
Unhappy Who on here is REALLY good at electrical?
I've got some serious issues with the cluster in my '88 and could use some help.
The cluster housing has been checked and all continuity checks were good, all the gauges themselves seem to be okay, but the #1 speed sensor, the fuel gauge, and the oil pressure gauge are all non-functional.
Any thoughts or advice will be appreciated.
Old 04-19-2011, 05:04 AM   #2
http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=136
The speedometer has nothing to do with the rest. If your other gauges such as the tach, boost or battery gauge, etc are functioning then the issue is most likely a burnt trace in the flexible circuit on the back of the cluster.
Old 04-19-2011, 11:34 PM   #3
mirage83
Would a burned trace show up in the continuity tests on the various locations on the back of the cluster as shown in the TSRM for gauge problem testing?
Old 04-20-2011, 06:35 AM   #4
On those type of circuits a burnt trace is generally VERY obvious and hard to miss with just a visual inspection; Fractures are harder but as this isn't subject to much flexing it's a moot point.
I don't recall the test procedure, however I'm sure it's not very in depth. I suggest you use the TEWD and follow each end back to it's source trace where the harness connects. Check if the couple circuits you're having trouble with share a common trace.
Old 04-20-2011, 07:23 PM   #5
mirage83
Well, I decided to do a quick swap to check whether the cluster housing and such was bad, but the replacement unit I put in displayed the same issues as my original, so I'm (for the moment at least) ruling out the cluster as the culprit.
Gotta get this thing running right, meaning I'm reduced to going through the motions you noted and have started tracing each circuit from it's particular cluster plug backwards. Tedious, but I can't see any other realistic options to finding these problems.
Next time I decide to rescue a car in this condition, somebody please get proactive and put me out of my misery to come.
Old 04-20-2011, 08:26 PM   #6
Don't test for a break, start with the 7.5A Gauge fuse and trace for voltage drop across the circuit.
Old 04-21-2011, 04:55 PM   #7
mirage83
Okay, I'll take that route and see what turns up. I appreciate the assist.
Anyone compared good 4" to good 5" or 6" spkrs in the front? wdb Car Audio and Alarms 4 07-29-2010 09:57 PM
Who has the best quality stuff? ozsupra Car Audio and Alarms 51 12-24-2008 11:29 AM
Good Karma scruffboy Non-Generation Specific Questions 1 04-14-2006 01:18 AM
