Old 04-05-2011, 01:34 AM   #1
g_rizzo
g_rizzo is on a distinguished road
Default Idle air control valve ?
Can someone expalin the symptoms of a bad idle air control valve, i know the bearings are not ceased in it but whats the best way to tell if it is bad, also the hose going into it the large 1/2inc from the intake are they always slightly kinked going into the vale
90 Turbo A.T
g_rizzo is offline   Reply With Quote
Old 04-05-2011, 05:09 AM   #2
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
There is a test procedure in most repair manuals. It's a "stepping motor" so that means to get the valve plunger to move in one direction you have to activate the positive pins in a sequence. The reverse sequence moves the plunger in the opposite direction. After shutting off the engine you should hear a buzzing clicking sound that is indicative of a functioning idle control valve. You can disassemble and check for crud build up on the plunger and clean it. Be sure to get the check valve that goes into the intake manifold installed in the correct direction. The rubber diaphragm goes into the manifold body. Under turbo boost conditions it blocks air from backing out through the idle valve. If your hose is pinched it may not be a factory formed hose. It should have the same texture as the other hoses used on the intake bellows.
Old 04-05-2011, 05:18 AM   #3
Midwest_Mudder
Midwest_Mudder is on a distinguished road
I may be having issues with mine, haven't had the time to test it yet. Idle is all over, yet timing is perfect, new plugs new wires and no vacuum leaks. It'll go up, stick, then come down too far and nearly kill it, if i tap the gas it sticks then will drop too far, then over correct. It does this when warm and when cold. Motor runs strong in all other aspects. Back when I had a neon (the only other computer controlled car I have owned) it's IAC went bad and was doing the exact same things. I was told I could have possibly saved it by cleaning it up.
So, my question is, what is the best way to clean the dang thing. There was some gunk in my throttle body when I bought the car so its not a far reach to think the ICV would be gunked up also. I don't want to pull it off, then clean it with something and have whatever I used kill it.
Also, if it does need replaced, what all other toyota cars have the same part in them? I've found out pretty fast that you put "Supra" in front of the part the damn auto places tack on an extra 50 bucks.
Anyway, not meaning to threadjack, I believe this is all on topic, and I didn't want to make another post when it could all be answered here.
Midwest_Mudder is offline   Reply With Quote
Old 04-05-2011, 06:16 AM   #4
Bru
Bru's Avatar
Make sure the throttle position sensor is in adjustment and working. You'll need an ohm meter, a set feeler gauges, an S shaped phillips screwdriver for tight places and the repair manual procedure to do that. It's helpful to have a couple alligator clip wires.
Old 04-09-2011, 08:11 PM   #5
g_rizzo
I have cleaned the valve and fixed the hose going into it. Now the car will stall from time to time without warning. I think i will check the TPS
1jz idle speed control valve 89_1j MKIII Supra 1 07-09-2009 03:04 PM
Valve Assy, Air Control Broken~ Help mkiiisupra MKIII Supra 7 11-12-2007 10:50 PM
Air Control Valve nickvash0104 MKIII Supra 0 03-07-2006 06:26 PM
