Old 04-02-2011, 04:12 PM   #1
Travis89Turbo
Travis89Turbo's Avatar
Originally Posted by Johnsupra View Post
ya running rich and backfiring at not giving any codes everything is coming up ok
You probably have leaking capacitors in your ecu. I kno you said u tried other but 95% of 1j ecu have leaking capacitors I had to replace mine not even a week ago.
The good thing is that it is easy to do if u kno how to solder. And about $2 for parts. Here is a link.
http://www.toymods.org.au/forums/sho...placement-info
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 04-02-2011, 08:31 PM   #2
Knock is another possibility.
Old 04-02-2011, 10:39 PM   #3
Johnsupra
Johnsupra's Avatar
Johnsupra is on a distinguished road
tried that to is there any relays or units inside the car that can cause this
Johnsupra is offline   Reply With Quote
Old 04-03-2011, 12:19 AM   #4
Travis89Turbo
No.
You could always get a piggy back system and an a/f gauge. The 1j runs rich from the factory.
A dirty airfilter can also cause it!
Check your spark plugs. gapped between .020 to .028 all 1j are really picky when it comes to spark plug gap. mine has to be set at .024 EXACTLY or it will putter.
stock 2jzge
Old 04-03-2011, 01:53 AM   #5
No, extra rich fuel and reduction in timing is a function of the ECU in the presence of ping and knock. If you have changed the octane of the fuel you're using and the climate hasn't changed significantly a ping could be bad news; If it's gotten hotter and/or drier and you aren't using a high octane fuel you may want to try it and see if performance improves.
How did you test the MAP sensor and the IAT sensor?
Old 04-03-2011, 10:52 AM   #6
Johnsupra
Johnsupra's Avatar
well iv had this over fueling ploblem with a while and could not get it sorted . so i went and bought another 1jz car that was running perfect and swaped engine and everything in to mine and it running the exact same as my old engine was
Old 04-03-2011, 10:29 PM   #7
What are you basing the diagnosis on? Mileage, backfiring, Air/Fuel gauge (in which case wide band or narrow?).
Have you tried running with the O2 sensor disconnected? Mileage that way should be CLOSE to stock. I'm assuming the engine has an O2 sensor..
What shape is the cooling system in?
Old 04-02-2011, 10:36 PM   #8
Johnsupra
Johnsupra's Avatar
i have tried a ecu i know is working perfect and its stil the same
