Old 03-30-2011, 04:20 AM   #1
Sonyps307
Default New Head gasket and now it's blown
So my 7mge was rebuild by this shop and I guess they didn't do something right for the HG so 2,500 miles later it blows. So now they r on the hook to fix it. They asked me if I want arp bolts or studs because my old bolts might be the problem. So which do I pick and what torque for both. I had 75lbs on the stock bolts and Im using a stock HG.
Old 03-30-2011, 07:40 PM   #2
The old bolts should have been fine. They're not torque to yield fasteners so unless there is pitting or they don't measure at the same length you should be all set... That having been said, I don't like to rely on any fastener that old; Especially if the engine's over heated at any point.
Studs offer a higher clamping force and more consistent torque readings with less possibility of striction.... Plus if they're dumbasses and didn't chase the threads in the block (which can REALLY screw up torque readings causing you to torque FAR below your target) you will still achieve a close enough level of torque to not worry. Unless you're having the block and head milled you need to stick with the stock HG. The head should have been milled the last time so a good cleaning and lapping of both head and block are really all that should be needed as long as there's no warpage to either.
Old 03-30-2011, 08:10 PM   #3
El_supracabra
El_supracabra is on a distinguished road
sounds like every time ive let someone else work on my car.....
sorry to hear that. cre is absolutely right. Though if you are having the work done by a mechanic/shop there isnt much you can do besides tell them how stupid they are and that they should try ACTUALLY doing the job right.
If it wasnt for the warranty i would say switch shops.
good luck!
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
Old 03-30-2011, 08:48 PM   #4
Sonyps307
Check them out. http://www.jbsautomachine.com
This is where my motor was built. They do good work I guess just not on imports. Also they said everything was good and no pitting or warpage. Then they ordered a set of arp studs and a head gasket from a place that Specialize in import cars.
