Old 03-21-2011, 08:24 AM   #8
ochowdero
swearing is uncalled for in public..thats beside the point.
on the forums you got kids, teens, adult and some woman.. it offends some people and if your looking for help, polite language is a good thing practice, specially in life.
im not gonna give you a life lesson or tell you I dont swear cuz i do..
im just saying be polite on the forums, people help out alot when there respected..
try this "what the F#@k"
or
"WTF"
anyway,
if your leaking oil still, id replace the oil filter, and check around the oil pan to see if the gasket is leaking, if so get it replaced..professionally!
as for the coolant lines, just check every hose that comes from the inter cooler..replace necessary hoses and refill..flushing the system could help cause there may be a clog and may cause too much pressure causing it to leak.
as for the oil pressure, id check the oil pressure gauge. mine kept coming loose, plugged it in it worked for awhile then it dropped back down again.
check all those out again and get back to us.
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
