Old 03-04-2011, 07:38 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
A word of warring, always back off the brake shoes when removing the rear discs/drum. The shoes are held on with two pins and springs, one straight and one bent pin. If you pull the disc/drum off with the shoes locked up, or the inner drum is worn leaving a ridge preventing the disc/drum from coming off, you could stretch the bent pin (making it longer) that would then catch on the rear hub when re assembling.
The photos below show a set of new pins and an old stretched pin from removing the disc/drum without backing off the shoes.
