Old 02-21-2011, 07:22 PM   #1
rjSupra
rjSupra's Avatar
rjSupra is on a distinguished road
Default car suddenly wont start - never ran great anyway, esp. cold, now cranks, but won't st
Hello excellent forum,
Engine will crank but not run (had started & run without this problem ever including earlier this same day!).
88 Turbo AT, 131K, prob 5th owner and questionable history last 6 years on maintenance. It mostly sat and was run only occasionally on short private road - what that last owner told me anyway.
With a good batt, it always started right up. Idle steady and solid about 600 RPM at start, no real 'high idle' which dropped after warm. Dunno if that's normal but my Integra has a high idle on start.
But NOW, it won't start at all. It cranks no problem (new batt), but chugs like it's about to run on it's own and won't get the final 5% there if you know what i mean. I jumped the +B and FP terminals, and could hear a distinct fuel (or liquid at least) noise right around the throttle body so I am guessing I am getting fuel ok?
Just did the error codes by jumping E1 & T. Got codes 14 and 21. I did look them up and will search here more, but I am a little not sure what's the next step.
ALSO, 10 minutes ago I put the T & E1 jumper in (with it not in all the way b/c error codes did not flash), and then I noticed a smoke starting to come out at the back top area of the motor (an accessory or component up high and back, not the motor itself). I also smelled like a light burning plastic type of smell. I smelled that before this morning before I had the hood up and saw the smoke. It was not smoking on a lot of earlier attempts with the hood open though, just the last time. I've jiggled the CPS connector and the connection look ok. Turbo O2 sensor wiring looks ok.
The TEMS leds go up to 3rd LED sometime as I am trying to start the car, and then back to 1. I can hear the suspension clicking about in the rear.
Before this not starting problem when it ran the last 6 months I've had it, it runs like shit at 2000 rpms with AT in Economy and Overdrive enabled. Pulls like I am towing a boat, cold or warm 2K Revs on the motor is bad, stumbly and low low power. If I hammer it with
'Power' on AT setting and get full boost it does get more respectable. OH, and I get 14.3 MPG, yeah, driving like an old lady with mostly highway, you read that right. 15mpg if I am 'lucky'. what does that also indicate? (I use premium fuel).
Runs pretty good at 70 mph +, it seems to really pick up and have power and not ever stumble at 2300 RPM+. 2500 RPM and fully warm it's almost dreamy although not quite.
This Supra hates the cold. If I start it under 50 degrees or maybe 40 at least, the motor starts, runs, revs mostly normal (stumbles on initial throttle tip in), but put in in 'D' press the gas and she'll barely move on the flat. Even flooring it, and i mean almost not move at all. Ditto for 'Reverse' D1 etc... After 10-15 minutes idle and normal op temp, it will drive down the road. Hills of most kinds present a challenge for this motor too.... it has very weak power. And even full boosting isn't exactly going to impress your co-driver.
There was a suggestion it's tranny related by chatting to a Hyundai tech friend and a chevy mechanic friend of friend (the cold not moving problem).
The 2nd to last owner I tracked down, and 7 years back he said he noticed a 'power problem' the last stretch of him owning it and did not know what it was. Also he and last owner don't know about HG and if it was ever replaced etc... The car did come with full parts to do a Tran swap to Manual (lucky me), a throttle body, a head that was done 'perfect'.
I think, maybe (??) I have two separate problems here? Maybe a 02 sensor gone bad that makes it run like shit? and now won't start? And maybe something gone bad in the AT that makes it a grouch when cold?
(and also due to a massive coolant leak problem - that stupid 90 small hose underneath the thermo housing - I pulled the CPS to remove the water outlet housing and replace its gasket - another leak pre-emptive repair while I was in there - and replaced the oil seal and correctly put back in the CPS while aligned at #1 TDC. The car ran identically before and after I did this, so I don't think at least a CPS timing issue is present).
Any help would be greatly appreciated!!
88 Supra 7M-GTE Turbo, TEMS, Targa stock
rjSupra is offline   Reply With Quote
Tags
engine start, problem, will crank
Cold Start System Testing (hard starting) mrnickleye MKIII Supra 12 11-13-2010 08:32 PM
Cold start issues??? Stanghunter MKIII Supra 1 07-19-2010 08:48 PM
Cold Start System atsomepoint Non-Generation Specific Questions 1 08-16-2007 03:31 PM
Waterfall sound on cold start! HELP! 88 MARK3 Non-Generation Specific Questions 7 06-29-2006 03:45 PM
my car only start when cold? supfoo514 MKIII Supra 3 06-04-2006 11:22 PM
