Old 09-20-2005, 12:26 PM   #11
[QUOTE=Prez420]
Originally Posted by shiftinsidez92
if you go with that turbo set up, how in the hell do you connect it to your exhaust?
that what I want to know as well. I have a DDP on the way and want to know if it will fit.
anyone?
nope your bic ddp won't fit that setup... you can get one for the SP turbos i believe but that's about it
to get that setup to work on any car you will need a custom exhaust elbow & flange made
Old 09-20-2005, 02:36 PM   #12
Prez420
Prez420 is on a distinguished road
the problem being that I dont even know the diff between a turbo timer and a boost controller.
I need help
Prez420
1987 Supra Turbo
www.blackrosetattoos.com
Prez420 is offline   Reply With Quote
Old 09-20-2005, 08:00 PM   #13
rnoswal
rnoswal's Avatar
Yeah, just makeing fun, no harm I hope, just have nothing better to do. 100 plus f**king degrees outside, so going crazy!
Russ
Old 09-21-2005, 12:31 PM   #14
ahh... k hehe.. you shoulda said
turbo timer will keep your engine running for however long you have set it when you turn your key off and pull it out of the ignition....
turbo time down keeps your turbo in happy healthy condition
boost controller: they come in alot of forms, single stage, dual stage, triple stage, manual bleed off type
whatever boost controller you get (2 stage electronic is usually best) will control the wastegate that hangs off the side of the turbo... instead of your wastegate opening at 6 or 7psi stock... the boost controller will hold it closed for longer therefore you end up with more boost
quite kool little toys
Old 09-21-2005, 01:13 PM   #15
Prez420
I still dont quite understand the timer. how does it keep the turbo healthy? you will have to excuse my stupidity, but I need to know before I buy.
does having the DDP change anything with the boost controller?
what stage is this?.. http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
what are my options when it comes to upgrading the turbo with the DDP?
and if I do upgrade the turbo, what are my options as far as new headers?
and what are my options WITHOUT an upgraded turbo?
so many options... I love it
Prez420
1987 Supra Turbo
Old 09-21-2005, 01:22 PM   #16
the turbo timer cools down the turbo by allowing it to idle... running more oil through it and cooled water
it also helps with heat soak
a few ppl have found that when they go to the shop & stop then buy whatever they're gonna do then come back to the car it's a little harder to start
so by running the engine for a min before shutdown is just good overall... you need a fancy $200 turbo timer, just as long as it is settable for 1min to say 5mins it'll work fine
the boost controller doesn't get altered by the ddp
Old 09-21-2005, 01:28 PM   #17
Prez420
suprra_girl you are a wealth of information. thank you very much. what stage is that controller I pasted in my last post?
and how long would I want my engine running after I shut down? just one min?
Prez420
1987 Supra Turbo
Old 09-21-2005, 01:36 PM   #18
too be honest i'm not up to the play with all of HKS's product
i'm sure someone else here is familar and can let you know if it's bleed off or electronic and what stage it is
i believe the sp58gt turbo takes the ddp and then of course the ct26
well the sp58's can bolt straight on to our manifold (aapmotorsports is currently offline) but heres some turbos
http://www.horsepowerfreaks.com/pric...os/Turbos_Only
or you can buy full kits
http://www.horsepowerfreaks.com/pric...bos/Turbo_Kits
Old 09-21-2005, 01:38 PM   #19
as i'm typing a reply u've already written another LOL
it depends on how hard you've been boosting
if just cruising no boost you can leave it for 10-20secs then switch off
if a bit of boost here n there a wot here n there about 40secs
if you have been boosting hardcore right before you arrive at your destination yeps 1-2min will do ya
Old 09-21-2005, 02:35 PM   #20
Prez420
so many F'n turbo options... geez. endless and complicated. I need a teacher. ~sigh~
Id love to buy a kit, but it comes with alot fo stuff I wont need... filter, intake pipes, downpipes... I have all that already.
thanx for all the info and links suprra_girl. again your wealth of info is very appreciated.
Prez420
1987 Supra Turbo
