Old 02-13-2011, 02:17 AM   #1
looneytune_2004
looneytune_2004 is on a distinguished road
i forgot i have a 7mge with a 5 speed
looneytune_2004 is offline   Reply With Quote
Old 02-13-2011, 02:25 AM   #2
24? advanced?! In what way did it fail? NOx? Did you remember the diagnostic jumper before testing the timing?
http://www.cygnusx1.net/Supra/Librar...ction=FI&P=118
You should read through the diagnostics for the full system:
http://www.cygnusx1.net/Supra/Librar....aspx?S=EC&P=1
Old 02-13-2011, 02:37 AM   #3
looneytune_2004
yes it was and its at 24 degrees BTDC when it should be 10 degrees BTDC.
Old 02-13-2011, 04:33 AM   #4
Check your mechanical timing first. That much advance and you'd be overheating if something mechanical wasn't off too..... or you've got the god of all cooling systems.
Not Passing emission's :-( SDK MKIII Supra 14 04-18-2010 05:17 AM
emissions FYI ddmcse MKIII Supra 0 02-01-2008 12:34 PM
Went through Emissions today.... IHateHacks MKIII Supra 32 07-03-2007 07:31 PM
Emissions gorillaguy8 MKIII Supra 10 04-10-2007 12:33 AM
Emissions drmmr15 MKIII Supra 1 01-19-2007 04:09 PM
