Old 02-09-2011, 10:01 PM   #1
bdavis89
bdavis89 is on a distinguished road
Arrow 88 1jz swap ignition problem. HELP plz!
i recently found a 88 with only 95k miles on it with the 1jz swap done the owner told me he couldnt get the engine to start had fuel air and compression but no spark..... any ideas on what the problem could be?
bdavis89 is offline   Reply With Quote
Old 02-10-2011, 03:23 AM   #2
Travis89Turbo
Travis89Turbo's Avatar
First thing id check is make sure the ignitor is plugged in or even present..its next to junction box, specific for the 1jz.. THEN recheck that you have compression and fuel... Check plugs while your in there. Also inspect the coils for cracks and be easy on them they break fairly easy.. I'D check the timing belt if everything else checks out.. make sure dead timing is set properly (all the marks line up).
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Tags
1jz ignition problem
4runner 7MGE swap idle problem grabber MKIII Supra 3 06-26-2008 11:45 PM
ignition problem??? ratiugslinky MKIII Supra 30 05-01-2008 06:29 AM
Ignition Problem Burning Pyro MKIII Supra 9 04-24-2008 02:31 PM
7mge swap, electrical problem 89n/aA/T-2turbo5spd MKIII Supra 5 08-15-2007 06:51 AM
