Old 02-09-2011, 02:17 AM   #1
The 2JZ-GE takes a turbo much more readily than the 7M-GE.... MUCH MORE. You can even run it on 7M electronics but you lose some power potential there. At a minimum I would run the 2JZ-GE electronics along with an aftermarket boost controller and upgraded injectors... Best would be running 2JZ-GTE electronics with stock 2JZ-GTE injectors or better and a good fuel controller.
It's been a long time but I think there is even a suitable oil return from the turbo.
You should check in the MKIV section for additional info though.
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
2jzge bigger injector question tegrab18 MKIV Supra 0 03-18-2010 01:47 AM
1.5jz question. Javier Wilde MKIV Supra 1 06-02-2009 12:35 AM
Question for someone who has actually seen the outside rear lock mechanism finaltable MKIII Supra 0 10-22-2007 02:44 PM
2jzgte 2jzge zbower Non-Generation Specific Questions 1 06-19-2006 10:14 PM
