Old 02-08-2011, 09:04 PM   #1
tanahara
tanahara is on a distinguished road
Default 2jzge na - t odd question inside
I am doing a 1jzgte swap on my sc300 and my dad just bought my old mk3 supra and its motor craped its oil out and ran with no oil for a bit. He is considering getting my 2jzge from my swap and rebuilding it and turboing it what will be the problems with putting that in a mk3 ?Thanks guys alot iv searched but no one was in my situation :P
tanahara is offline   Reply With Quote
Old 02-08-2011, 09:50 PM   #2
jdmsoup
jdmsoup's Avatar
jdmsoup is on a distinguished road
so pretty much you just want to know what you will need to swap the 2jz into an mk3?
87 Supra Turbo.
JDM 7M-GTE.
CT-26 set @ 10-12 pounds.
xs sport manual boost control.
hks ssq bov.
greddy front mount.
3"downpipe with 3" straight through piping back to tip
kyb shocks.
"In life its not what you know, its who you know"
jdmsoup is offline   Reply With Quote
Old 02-08-2011, 10:02 PM   #3
tanahara
sure i have some parts lists gathered from searching but do we have to change pistons or anything internally when we na - t it.
Old 02-08-2011, 10:28 PM   #4
907mge
907mge's Avatar
It will probably be the same as turboing a 7mge. But I think the 2jz ge is built better. How many mile are on it now? Because its rare to see a low miles sc300. So is a rebuild in order?
Old 02-08-2011, 10:43 PM   #5
tanahara
210k was on my 2jzge so ya lol
Old 02-08-2011, 11:25 PM   #6
907mge
907mge's Avatar
I would not turbo it with that many miles without a rebuild. So then you would have to ask the question of, would it be easier to just get a jdm 1jzgte or 2jzgte?
Old 02-08-2011, 11:33 PM   #7
tanahara
Well this is doing the work ourselves new gaskets etc etc
Old 02-09-2011, 02:17 AM   #8
The 2JZ-GE takes a turbo much more readily than the 7M-GE.... MUCH MORE. You can even run it on 7M electronics but you lose some power potential there. At a minimum I would run the 2JZ-GE electronics along with an aftermarket boost controller and upgraded injectors... Best would be running 2JZ-GTE electronics with stock 2JZ-GTE injectors or better and a good fuel controller.
It's been a long time but I think there is even a suitable oil return from the turbo.
You should check in the MKIV section for additional info though.
2jzge bigger injector question tegrab18 MKIV Supra 0 03-18-2010 01:47 AM
1.5jz question. Javier Wilde MKIV Supra 1 06-02-2009 12:35 AM
Question for someone who has actually seen the outside rear lock mechanism finaltable MKIII Supra 0 10-22-2007 02:44 PM
2jzgte 2jzge zbower Non-Generation Specific Questions 1 06-19-2006 10:14 PM
