Old 02-08-2011, 02:10 AM   #1
kcahrens
kcahrens is on a distinguished road
Default Stock BOV Test?
I'm tearing apart my supra and replacing pips and a assload of other things, any one know how to test if the BOV is functioning properly?
88 Supra Tegra 7M-GTE Manual
Seattle, Washington (Granite Falls)
kcahrens is offline   Reply With Quote
Old 02-08-2011, 02:35 AM   #2
Travis89Turbo
Travis89Turbo's Avatar
On the 7m it is actually a bypass valve (bpv) If you can blow through it, its toast. The bosch bpv is the best replacement they came out of saabs. I have an extra one, or you can get them off eBay or driftmotion has them!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 02-08-2011, 02:48 AM   #3
kcahrens
Yeah you can defiantly blow through mine. effff.
Old 02-08-2011, 03:04 AM   #4
supraturbo_mk3
supraturbo_mk3 is on a distinguished road
Well if you hear a flutter around full boost it's either not adjusted properly or it's not working properly....Now it's very uncommon for a piston type bov to go bad....I guess you could check the piston movement make sure it's functioning properly. You could also inspect the spring. My guess is your bov is fine may need adjusted depending on what bov you are using.
IF IT AINT A SUPRA IT AINT SH*T!!
87 Supra N/A JDM 7MGTE, 8psi, 2.5inch Exhaust, 18inch Rim's, 255/45/18 rear, 255/40/18 front, 3inch DP, Ported 3inch elbow, Stage 2 6 puck Clutch
95 Eclipse GST 15psi, 3inch Stainless Steel Exhaust, 3inch DP, MBC, 2.5inch Upper I/C piping, Short Throw Shifter, Stainless Steel turbo inlet, Type S BOV (Sold)
89 Supra Turbo, 12psi, 3inch Exhaust, Ebay intake, 2.5inch Upper I/C piping, ARP Head Studs, Stainless Turbo Manifold Tial BOV (Sold)
(Sold)
supraturbo_mk3 is offline   Reply With Quote
Old 02-08-2011, 03:08 AM   #5
Travis89Turbo
7m bpv go out quite often infact on both of my 7m I ever owned they both went bad. stock bpv cannot be adjusted.
Here is some good reading!
http://www.toyota-supra.info/forums/...to-intake.html
stock 2jzge
Old 02-16-2012, 10:58 PM   #6
DRAG-N-DRIFTER
DRAG-N-DRIFTER is on a distinguished road
Default My stock BOV on my MKIII went bad
My stock BOV on my MKIII went bad so I took it apart, found sludge built up.... Cleaned it up, put it back together again and sealed it, now it works like new...
DRAG-N-DRIFTER:gr inking:
DRAG-N-DRIFTER is offline   Reply With Quote
Old 02-16-2012, 11:38 PM   #7
If you have anything besides the thinnest film of oil (from the PCV system) then you've got bigger problems... see: excessive blow-by/bad rings and blown turbo oil seal.
Old 02-17-2012, 01:36 AM   #8
DRAG-N-DRIFTER
Unhappy
Getting more for the MKIII- stock Grandavi MKIII Supra 10 10-25-2010 08:30 PM
Emissions Test Info in "Your" Area/State mrnickleye Off Topic Forum 9 05-01-2006 01:11 AM
Emissions Test Info in "Your" Area/State mrnickleye Supra FAQ 0 03-05-2006 06:01 AM
