Old 02-03-2011, 01:33 AM   #1
Supra Saiyan
Supra Saiyan's Avatar
Default HELP, Downpipe installation + which DP.
This is the one i'm going to get..
http://cgi.ebay.com/ebaymotors/Toyot...ltDomainQ5f100
UNINSTALLATION + INSTALLATION OF DP
I think I should just unbolt the down pipe from the turbo elbow and the elbow from the turbo. Then get under the car and unbolt the stock down pipe from the cat.
Then slip on the new one in it's place with all the new gaskets. Bolt it in and that's it.
Please let me know if installation is as easy as that..
Old 02-03-2011, 05:31 AM   #2
Supra Saiyan
or should i do this dp..
http://cgi.ebay.com/ebaymotors/Toyot...Q5fAccessories
I keep hearing that divorced dp is the way to go.. idk though.. Is it legal in Oregon. Is it legal at all. You can't use test pipes here.. Anyways I don't think it is since your bypassing the cat in some way. Anyways, what one is better.. Most likely it is better because if you can create anything that is somewhat a bypass you get a gain (in a turbo car)..
Old 02-03-2011, 08:42 AM   #3
mkiiisupra
http://www.bicperformance.com/products.htm
3" Downpipe with Divorced Wastegate (DDP) -- 369$
Always worth the extra coin to skip the cheap Chinese made ebay products
The purpose of divorced pipe is it gets the turbulent air released from the waste gate out of the main flow which helps improve exhaust flow.
If your worried about legalities they will recirculate the divorced flow back into the main pipe as well.
1990 Toyota Supra Turbo A/T
Old 02-03-2011, 04:09 PM   #4
Supra Saiyan
Thumbs down
Its just a pipe though. I don't get why I would spend more on the brand name. What is the difference? Please just give me an explanation so I understand. Its a pipe with no moving parts to me. A long as its thick enough and made if the right metal, I would even put a mario brother warp tube down there.
Old 02-03-2011, 05:52 PM   #5
907mge
907mge's Avatar
Its the good old "you get what you pay for" theory. Which is why I don't like much of what is sold on ebay. The pipe looks good in the picture but without seeing the welds and quality of metal, you don't know what is will look like down the road. I don't know how the tanabe here is:
http://www.advancespeedshop.com/tana...33-p-2230.html
But I have some suspension braces of theirs on my celica that are pretty nice and they are made in japan.
Old 02-03-2011, 06:05 PM   #6
Supra Saiyan
Ok this is the one I will get.. Better metal, and its divorced but legal.. Comes with gaskets too!!
So will someone confirm my instructions for the installation? Is it just that easy? a few bolts and bang done..?
Old 02-07-2011, 06:38 AM   #7
supraturbo_mk3
supraturbo_mk3 is on a distinguished road
It's a bitch to do I can tell you that....There is like almost no room to work with....Measurements of the down pipe are almost always off....Make sure you have new bolts and lock washers ready.....Some PB blaster a friend to help you re attach the cat to the down pipe because it's a bitch....Probably want to go ahead and get new rubber anchors for the exhaust too because they are probably dry rotted and cracked but anyway good luck with it.
IF IT AINT A SUPRA IT AINT SH*T!!
87 Supra N/A JDM 7MGTE, 8psi, 2.5inch Exhaust, 18inch Rim's, 255/45/18 rear, 255/40/18 front, 3inch DP, Ported 3inch elbow, Stage 2 6 puck Clutch
95 Eclipse GST 15psi, 3inch Stainless Steel Exhaust, 3inch DP, MBC, 2.5inch Upper I/C piping, Short Throw Shifter, Stainless Steel turbo inlet, Type S BOV (Sold)
89 Supra Turbo, 12psi, 3inch Exhaust, Ebay intake, 2.5inch Upper I/C piping, ARP Head Studs, Stainless Turbo Manifold Tial BOV (Sold)
(Sold)
supraturbo_mk3 is offline   Reply With Quote
Downpipe Advice cgreiner MKIII Supra 2 03-16-2009 01:34 AM
3" Downpipe Reeves MKIII Supra 10 08-31-2006 10:35 PM
Divorced Downpipe VS. 1 piece elbow-downpipe 87sleeper MKIII Supra 1 10-04-2005 04:50 PM
