Old 01-28-2011, 03:35 AM   #1
amueller626
amueller626 is on a distinguished road
Default can I drop a turbo engine into a 86 non turbo
Are there any issues with dropping a 7MGTE turbo engine into a 86.5 non turbo?
Wiring harness? Vaccuum lines?
Thanks,
Bill
amueller626 is offline   Reply With Quote
Old 01-28-2011, 07:30 AM   #2
Well, you'll need to swap in a GTE oil cooler setup or install a full flow oil cooler (MUCH better, the stock GTE setup is crap). You'll also need to swap in the GTE electronics (ECU, air flow meter, coil packs, wire harness, etc.). The GTE came mated with a different transmission than the N/A, it you want to swap that in too you'll at least need to swap the front half of the drive shaft. The N/A also has a lower end gear... if you're looking for a smoother ride you'll want to swap in either a 3.91 or a 3.73 from a turbo model. You'll need the speedo drive gear for which ever diff you choose to match with the transmission or your speedometer and odometer will be off.
Old 01-30-2011, 04:33 AM   #3
amueller626
Thanks! You helped me talk my son into keeping it stock.
Old 01-30-2011, 05:33 AM   #4
ROFL!!! Well, I'm here to help.
If he decides down the road that he really has to have a turbo he's bettor off with a swap than adding a turbo to the N/A.
7mgte or other turbo engine dave MKIII Supra 3 10-26-2010 08:44 PM
