Old 09-19-2005, 01:23 PM   #11
bigal0043
bigal0043's Avatar
bigal0043 is on a distinguished road
didnt take it to the track this weekand rained like a bastard..... but probally good in the end i blew a collant line just driving around town... it was in the back of the valve cover must have been weak... seemed alright when we had put it on... havent check since about the noise will tonight after i check coolant level... the little bird cage came on last night but went out after got up to temp...
bigal0043 is offline   Reply With Quote
Old 09-22-2005, 06:59 AM   #12
Poodles
Launching at 5500 RPM is a bit high on street tires, you'll spin a LOT. Around 3k is the limit on mine...
The thing about getting a radiator cap with too much pressure is that it will find any weak spot in your system, like a small coolant line at the back of the head... Stock radiator cap is fine, but make sure you don't ever shut your car off right after racing, let it idle down for a while since you're pushing it so hard.
Short shifters aren't cheap, best thing to do is get a poly version of the shifter seat and cup on the bottom of the shifter to get rid of the nasty amount of play in the shifter. marlincrawler.com sells them, it's a HUGE improvement. Also, a solid shifter knob usually helps too, I have a ball off a third gen f-body on mine...
Old 09-22-2005, 01:46 PM   #13
WiseAssJester
Holy crap..
Can all Supras launch so high?
I heard that the majority come with limited slip diffs, is that true?
My car has an open diff and has to launch at idle. And if I don't feather the clutch I'll be spinning tires through third. :-/
Mk3 Supra Road Test Sinistral MKIII FAQ 8 02-14-2010 08:48 PM
twins or single for road racing? CougarDS MKIV FAQ 14 04-27-2009 06:51 AM
Max safe long straight performance in a road race? Humba MKIV Supra 7 12-25-2008 05:38 AM
November 2006 road and track. Florida Mike The Future of the Toyota Supra 7 10-01-2008 12:36 AM
Oxity Bank Note Road Rally Oxity-X Road Racing & Autocross 1 05-22-2006 12:54 PM
