Old 01-11-2011, 05:25 AM   #1
xander024
xander024 is on a distinguished road
Default Whats different 7mge/ 7mgte
for starters im not retarded i kno tha MGE is NA and the MGTE is turbo...
but where im confused is the specs and what makes the compression different...
i know u can turbo-charge a MGE fairly easy in theory but lots of tuning is involved, but these are the specs that confused me
7MGE Specifications:
Displacement: 2954 cc (180.2 cu in)
Bore: 83.00 mm (3.27 in)
Stroke: 91.00 mm (3.58 in)
Compression Ratio: 9.1:1
Weight: 199 kg (440 lb)
7MGTE Specifications:
Displacement: 2,954 cc (180.3 cu in)
Bore: 83.0 mm (3.27 in)
Stroke: 91.0 mm (3.58 in)
Compression Ratio: 8.4:1
Weight: 210 kg (463 lb)
Source: http://en.wikipedia.org/wiki/Toyota_M_engine
pretty much i was thinkin' of doin an engine swap but it seems i should turbo charge my MGE instead of buying a new engine... help plz!
xander024 is offline   Reply With Quote
Old 01-11-2011, 06:46 AM   #2
The GE some very different timing and fuel maps (you can't just reflash the stock ECU you'll need either a couple piggy backs to tune out the differences, a standalone EMS or to swap in GTE electronics to safely compensate). The GTE uses a higher flowing oil pump, has oil squirters to help cool the pistons, has larger injectors and is accompanied by a higher flow fuel pump... it also uses lower compression pistons (they have a deeper dish which reduces static compression).
In my opinion, having done this before, I highly recommend you do the swap... you'll save a lot of money and start out with a setup that's going to take upgrades with more grace.
Oh, forgot to mention that the ISCV on the GE doesn't have a back flow valve to prevent boost leak and both cars have different intake cams.
Old 01-11-2011, 05:56 PM   #3
xander024
thanks for the wisdom... u just saved me a lot of $, this all makes a whole lot more sense now
Old 01-11-2011, 06:28 PM   #4
cre as i said before you should piss in a bucket and sell it as "cre's magic snake oil." youd be rich.
Tags
7mge, 7mgte, engine swap, turbo, turbo conversion
7mgte to 7mge conversion help wayzhack MKIII Supra 7 09-07-2010 08:22 PM
