Old 01-09-2011, 03:06 AM   #1
Conga1991
Default Supra mechanics wanted!!
Need a Supra mechanic in the Seattle area, willing to pay, to come out and help me getting my Supra running. I swapped a gte into a ge, will turn over but there is no spark and the battery is always dead whenever I try to go out and test something. Im located out in Roy.
Or if there is anyone that is selling a turbo shell that is straight or knows anyone who is selling one, I will swap everything into that since my shell isn't the greatest and could possibly be a wiring problem. I've been working on it since May, getting the engine and tranny in.
All help is greatly appreciated!!
Old 01-09-2011, 11:18 PM   #2
its your electronics: see http://www.toyota-supra.info/forums/...-complete.html
post 3
Old 01-09-2011, 11:29 PM   #3
Conga1991
There's a difference though, I'm using a pre-89 gte harness and ecu for my 88 Supra. So how can it still be my electronics unless I need to change out my fuel pump
Old 01-10-2011, 02:20 AM   #4
ok you have gte electronics.. harnesses ecu ect. but your still experiencing no spark / start. and you troubleshooted accordingly ?
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=12
idk about the battery. maybe one of your power wires isn grounded or fubared.. we'll work it out.
Old 01-10-2011, 02:56 AM   #5
Conga1991
It turns over but no spark. and yes I troubleshooted using the tsrm manual. I even took my coil pack and ignitor to my friends supra and it worked fine on his and replaced my cps (not new, just used) and timed it from the tsrm.
Old 01-10-2011, 06:35 PM   #6
k how about your fuel pump then? it takes 3 things to start an engine. spark, fuel , compression
Old 01-10-2011, 06:47 PM   #7
Conga1991
It's not the fuel pump, I hear the fuel squirt when the key turns over to On or when I press the the accelerator
