Old 12-25-2010, 09:03 AM   #1
Supra Saiyan
Supra Saiyan's Avatar
Supra Saiyan is on a distinguished road
Default 89 turn,wiper,light column (Combo switch) DIRECT SWAP TO 88 supra
If I explained it wrong then understand please that I am saying the thing behind the steering wheel. I have a perfect working 89 one. I need to know before I waste time popping it off and such if it is a direct swap with my current 88?
Again, I have an 88 part that will be swapped for an 89..
Will this work no problem? direct swap??
Thanks
Supra Saiyan is offline   Reply With Quote
Old 12-25-2010, 09:15 AM   #2
Supra Saiyan
The part's name in the TSRM is COMBINATION SWITCH..
Old 12-25-2010, 09:44 AM   #3
Completely different parts according to the EPC. You could probably make it work but don't expect it to be plug and play.
Old 12-25-2010, 09:47 AM   #4
Supra Saiyan
Thanks, ya that sucks.. I don't want to tinker like that. Guess I will have to just sell off this perfectly good 89 one and find an 88 on ebay..
Thanks for you help..
Old 12-25-2010, 05:12 PM   #5
Green7mgte
Supra Forum Moderator
whats the year list for commonly swapped parts.
86/88
89
90/92
something like that?
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 12-26-2010, 06:24 PM   #6
Generally, 86.5 is compatible with MOST of 87.
87 is compatible with 88 (color and fabric option changes were made in '88, but that's not what we're worried about)
89 is compatible with 90
90 is compatible with MOST of 91
91 is compatible with MOST of 92 and 93
For the MOST part () though 86.5 through 88 is fine and 89 through 93 is fine... Also, these compatibility differences vary by market some depend on other factory options.
7mgte swap vs 1jz swap Supra Saiyan MKIII Supra 15 04-24-2012 02:58 AM
all their is to know for a 7mgte swap mkiii<3 MKIII Supra 0 10-03-2010 10:23 AM
differential swap or not kkiepvvessau MKIV Supra 22 09-02-2008 01:55 AM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
2JZ Motor Swap MDellboy420 MKIII Supra 3 09-11-2006 06:19 PM
