Old 11-30-2010, 01:02 AM   #1
xAimz
xAimz is on a distinguished road
Default Starting issue
Last problem i will post on here i swear!
Sometimes when my car is cold it starts right up, but when its hot, ( or having mood swings), it doesnt start
it has new starter new bat new everything basically, could it be the starter relay? i turn the key and it makes a click sound, but doesnt start. i gotta keep turning the key till it starts ( sometimes takes like 10mins)
xAimz is offline   Reply With Quote
Old 11-30-2010, 02:36 PM   #2
Green7mgte
Supra Forum Moderator
when you "click" does your lights an everything stop working? bad battery connection.
if it just "clicks" but you still have power. probably a bad starter connection. ground / power wire, something of the sort.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 11-30-2010, 07:27 PM   #3
xAimz
new battery, lights dont dim, the connection is good, it starts SOMETIMES
it has new starter also.
Old 11-30-2010, 10:00 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
See post 2 Link and post 8 Link
Old 12-02-2010, 04:31 PM   #5
Green7mgte
sounds like a plan
Supra FAQ
Supra MKIII FAQ
Old 12-02-2010, 06:06 PM   #6
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
I had this exact same problem on my 1987 Supra Turbo. It would start cold normally then after driving and going in somewhere when I came out I would have to cycle the switch 20 times or more to get the thing to start to catch. It turned out to be the fuel pressure up main relay which is located in the fuse box under the hood near the battery. It's the round metal one (MAIN). I got another one at the parts yard by matching the schematic on the side and the part number. RELAY M4 90987-02004 and 056700-4810 I have not had this problem since replacing the relay. Getting one from the Toyota dealer is way expensive. Other Toyota cars use this relay I think I got mine from a Celica. One thing you can try next time this happens is to take out the relay with a piece of towel because it's going to be hot and tap it gently, wait a few munutes, then put back in. If starts right up, it was the relay. Alternatively you could jumper the socket slots 3 and 4 which are the left two going front to back when you pull the relay out but I would only do this for testing purposes and not drive on it or leave the jumper in place.
Old 12-06-2010, 06:11 AM   #7
Green7mgte
EFI ohmmeter troubleshooting
eh dont know if thats gonna be helpful
Supra FAQ
Supra MKIII FAQ
Old 12-06-2010, 02:30 PM   #8
mkiiisupra
When mine doesn't start up right away i have to jiggle the cps wires then she starts right up.
1990 Toyota Supra Turbo A/T
Old 12-06-2010, 06:22 PM   #9
Bru
Bru's Avatar
I had the same cam position sensor wiring problem in the past too. It went away when I replaced the sensor. I recently rebuilt the sensor using a kit from kbox because the internal oil seal was leaking oil out through the front cover. I made an aluminum foil "cup" to catch the oil drips before I installed the kit. Installing the kit is not for the faint of heart, it takes some skills. I can describe my experience anyone's interested.
Old 12-07-2010, 04:29 AM   #10
Green7mgte
what?
a rebuild kit? you mean a new dust cover packing gasket and an o ring?
yea i bought that to.. 10 bucks from Toyota.
Supra FAQ
Supra MKIII FAQ
starting issue 88 supra automatic w/turbo help! ricerbaby MKIII Supra 2 04-15-2011 06:25 PM
vacuum lock issue? supraluver4life MKIII Supra 8 08-07-2010 10:54 PM
Starting Issue supraman8188 MKIII Supra 1 06-28-2010 04:01 AM
Engine Run-on Issue gottadiesel MKIII Supra 1 04-02-2009 07:26 AM
engine noise car dies after starting tex1116 MKIII Supra 7 11-18-2005 06:47 PM
