Old 11-27-2010, 04:37 AM   #1
xAimz
xAimz is on a distinguished road
Default MKIII Timing belt adjustment help
So i bought the car block machined and rebuilt, turboed, and he said he redid the timming on it, but while driving around 40mph like 2k rpm the car would jerk back and forth, he said the timing might be off,anyways whats the easyest way to do this, could some one give me detailed info, ive tryed searching ( found nothing), and looking tru my heynes manual(no luck again )
xAimz is offline   Reply With Quote
Old 11-27-2010, 11:44 AM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Adjustment Link and belt replacement Link
Old 11-28-2010, 03:30 PM   #3
the haynes manual has it all
i used it to to my timing
Old 11-28-2010, 04:17 PM   #4
Sonyps307
Get a timing light and check the timing
Old 11-28-2010, 04:30 PM   #5
before you can do anything with a timing light. you have to have a timing belt installed and alligned correctly...
but yes a timing light is a very handy thing to have. and should be used to set your dist. timing when finished with your belt.
Old 11-28-2010, 10:08 PM   #6
xAimz
well timing was at 12, now i gotta get a better cam shaft sensor
Old 11-28-2010, 10:42 PM   #7
Bill UK
AEM EMS
Bill UK's Avatar
12 deg with or without the check connector link ? and why replace the CPS ? just rotate it, as state in 8 (c) Link
Old 11-28-2010, 10:52 PM   #8
xAimz
guy said the cam shaft sensor might be bad, but engine runs good, except for the starting issue :/
Old 11-29-2010, 02:04 AM   #9
btwilson86
Super Moderator
btwilson86's Avatar
Yeah....... As Bill UK said, set the CPS. It's adjustable. Or you can go waste your money on a new one and STILL have to set it the exact same way...
Stripped Jumped Timing Belt batmmannn MKIII Supra 17 05-27-2010 12:48 AM
Timing belt questions..... Legionnaire MKIII Supra 0 09-17-2009 09:40 AM
New Timing Belt Direction Paul_NJ MKIII Supra 2 04-11-2009 01:16 AM
Replacing Timing belt Paul_NJ MKIII Supra 5 03-21-2009 05:35 PM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
