Old 11-23-2010, 08:27 PM   #1
Hall89
Hall89 is on a distinguished road
Default 350hp
I just bought a 1990 MK3 Supra and I was wondering the best way to get to 350hp... I have the non-turbo 7M-GE engine. Hope yall can help me out thanks
Hall89 is offline   Reply With Quote
Old 11-23-2010, 10:52 PM   #2
89ST
89ST is on a distinguished road
turbo = only way
89ST is offline   Reply With Quote
Old 11-24-2010, 12:38 AM   #3
seth959ci
seth959ci is on a distinguished road
yeah turbo is the only way to feasibly get that much power... i realize that after researching it for hours... i have a 7mge also and was wanting more power, just gonna do a stock rebuild for now
seth959ci is offline   Reply With Quote
Old 11-25-2010, 01:11 PM   #4
MA70-3.0GT
MA70-3.0GT's Avatar
yup, it is possible to build a "7M-GE(T)" but to be honest by the time you've faffed round with building and setup and crap you may as well just fit a full on GTE setup... although the GE bottom end is identical just needs turbo oil feed/return opening so if yours is known good with perfect hot oil pressure etc. and you can get hold of a knocking GTE engine plus ECU, loom, intercooler/piping you could do it that way...
Old 11-25-2010, 09:42 PM   #5
There are two significant differences in the bottom end that you forgot.
1) the GE runs a higher compression ratio which isn't safe (at least not with cast pistons) on a turbo setup
2) the GTE uses oil squirters to help cool the pistons (this REALLY helps ensure a longer life with cast pistons).
I've turbo'd a GE and it is far from a good choice.
Old 11-25-2010, 10:00 PM   #6
Hall89
Default ?
So if I do an engine swap I will also have to swap the transmission? In that case why not go for the 1JZ or 2JZ?
Old 11-26-2010, 04:23 AM   #7
907mge
907mge's Avatar
No the auto and manual both bolt to a 7m motor.
Old 11-26-2010, 07:12 AM   #8
Hall89
Default Ok
So my w58will bolt right on to a 7m-gte?
Old 11-26-2010, 07:32 AM   #9
No. Different flywheel, clutch, transmission mount and driveshaft. The differential is also different depending on the year of the car... I've posed all of this in the past three days, look through the forum a bit, you're asking NOTHING new. EDIT: You can swap over all these parts though... naturally.
As for why no do a 1JZ or 2JZ? They're still a lot more effort and money and the 7M is still a good engine.
7MGTE Build up suggestions 350hp - 400hp Supra Saiyan MKIII Supra 18 08-07-2010 03:12 AM
