Old 11-22-2010, 04:04 AM   #1
Supra Saiyan
Supra Saiyan's Avatar
Question Cat delete gains
I been searching around and have found a few different things out there for numbers upon deletion of the cats... One thing I found said there would be like 3-5hp gains, another said up to 15 per cat..?
Listen, I don't want to take the chance and have a cop find out I deleted the cat. So I am interested in doing the method another member here used. They chiseled out the honey comb inside the cat to keep the visual effect for cops. They claimed their gains where noticeable as well..
Can anyone help confirm this, or give some incite to using that method..? Also, I passed my emission with my catz with flying colors. Will I not pass with this mod or a test pipe.. (I mean its pretty much a test pipe)
Please reference this link to see one post I took some info from..
http://www.toyota-supra.info/forums/...test-pipe.html
Old 11-22-2010, 06:15 AM   #2
bassboy3313
bassboy3313 is on a distinguished road
yeah theres no way you will pass emissions with a cat delete or the mod that you described. if you live in a state that older than 1995 cars still have to get emissioned, theres no way around it. im so glad we dont have to emission test cars older than 1995.
bassboy3313 is offline   Reply With Quote
Old 11-22-2010, 06:21 AM   #3
couldnt help ya, havnt had a supra with a cat.
Old 11-22-2010, 06:24 AM   #4
Supra Saiyan
Well, its just a few bolts. I could delete for now, or use that "special method", and then when time comes I could put it back..
Would it be about the same to just do a high flow cat though?
Old 11-22-2010, 06:25 AM   #5
I've driven one Supra (GE) with a hollowed out cat, and then the same car after a used cat was installed... Although there *may* have been more power with the hollowed out cat (nothing that we noticed), the car ran better with the cat in place. The power built up much smoother than without the cat, and it helped the car have more pull in the higher rpm's (with the hollowed cat, it would fall on it's face around 5500ish RPM).
So I say keep the cat.
Old 11-22-2010, 06:33 AM   #6
Supra Saiyan
With this being said.. High flow cat would be better than stock right? I would still get a similar build up with out the "falling on the face around 5500ish RPM".. Yes, no?
Old 11-22-2010, 06:47 AM   #7
Well, I wouldn't really be able to say for sure; never drove anything with a high-flow cat on it. Exhaust systems are tricky, too much free flow and you don't build the pressure differences between outside air and the gases within the pipes that is required to help suck the exhaust out of the system, too little flow and exhaust backs up in the pipes and chokes the engine. Both scenarios will hinder performance.
I feel it should be noted that it's not about how much hp you can gain, but how the car drives. That extra 2 hp at XXXX rpm for a split second could translate to less hp throughout the powerband. In this scenario, you have more peak hp but performance will suffer due to the lower overall hp.
Oh, I also forgot to mention that the Supra I was referring to above had an unknown brand 2 1/2" cat-back system on it, both before and after the cat change.
Old 11-22-2010, 06:59 AM   #8
Supra Saiyan
Hmm, I see..
Old 11-22-2010, 07:02 AM   #9
Supra Saiyan
Thanks for all your input.. I have decided the only way to find out if I will in fact lose or gain will come down to trying the high flow cat and the test pipe on a dyno. This way I can see where I gain or lose along the power band...
Old 11-22-2010, 07:29 AM   #10
That's a good idea, be sure to post your results once you're able to do this
Average HP Gains (?30HP?) Supra Saiyan MKIII Supra 18 08-12-2010 03:00 AM
ABS delete jdmsoup MKIII Supra 8 06-22-2010 03:19 AM
Heater Delete joshtexican MKIII Supra 9 06-20-2010 05:15 PM
ABS delete matt1993supraTT MKIV FAQ 13 06-06-2010 05:23 PM
3" exhaust/2.5" wit not cats Hp Gains? supraman121 MKIII Supra 0 08-20-2007 06:09 AM
