Old 11-20-2010, 10:18 PM   #1
bassboy3313
bassboy3313 is on a distinguished road
Default brakes dont work in cold weather
Hello. This morning on my way to work, I noticed that my brakes were not working properly. First time I press on the brake it would go down to the floor with ease. I have to pump the brakes a couple times before it gets harder and even then its not up to par.
Does this mean I just have to bleed the brakes and I should be good? What do you think?
bassboy3313 is offline   Reply With Quote
Old 11-21-2010, 03:55 AM   #2
think you should bleed your brakes.. then take it around the block and see what happens. check your fuild level. does your brake light come on when you brake quickly from speeds above 35? if so its probably low fluid.
squishy brake pedal is vindictive of air in the lines..
Old 11-21-2010, 10:25 AM   #3
bioskyline
get a buddy and see if theres bubbles in the master when you hit the breaks. the rubbers that hold the plastic tank to the master went hard on mine, didnt seal properly, and was allowing air into the brake system. they would work for a while then get gradually softer, which sucks with an auto. if not id check to see if the master itself isnt shot, ie leaking fluid from the rear seal.
Old 11-21-2010, 02:05 PM   #4
bassboy3313
im gonna try and bleed my brakes today after work. i did notice that I can move the clear reservoir on the MC a little bit with my fingers too.
Old 11-21-2010, 10:12 PM   #5
bassboy3313
Thanks for everyone who responded. I bleed the brakes today after work and also found a leaky brake hose connection on the drivers side front wheel. bolt was loose that connected the brake hose to the caliper. im glad it was nothing major. thanks again.
Supra idea, simple, cheap cold air intake 82Supra MKII Supra 1 09-02-2009 02:43 AM
Lost my brakes today... wtffffff Kevin MKIII Supra 4 06-04-2009 05:50 PM
Two Issues: Front Brakes and Sporadic Vibration Chambers MKIII Supra 0 11-03-2007 04:15 PM
Brakes 5M Vs. 7MGTE panda-supra MKII Supra 3 03-22-2006 09:07 AM
Brakes acting up maksimus54 Non-Generation Specific Questions 4 07-06-2005 11:47 PM
