Old 11-02-2010, 11:07 AM   #1
fantasma87
fantasma87's Avatar
Default q45 throttle body 90mm will fit on....
that throttle body will fit on a stock 7mgte engine? any mods?
ARMY STRONG !!
Old 11-02-2010, 01:10 PM   #2
No, it won't fit the stock intake plenum.
Old 11-02-2010, 02:25 PM   #3
fantasma87
fantasma87's Avatar
the mount its bigger ? if i get a front face intake it would? but the connectors "plugs" are the same? thanks CRE for the info.
ARMY STRONG !!
Old 11-03-2010, 02:45 AM   #4
No, the plugs are not compatible. You'll need to get an electrical connector for the Q45 and then you need to rewire a couple things for it to work. No, not all FFIMs accept the Q45 TB... there are several popular throttle bodies used on FFIMs and you'll need to choose the TB accordingly. The Q45 is probably the post popular choice though, but make sure before buying.
The wiring details have been posted here and at supramania and supraforums a few times in the past. It shouldn't be too difficult to find with a little searching.
7gmte throttle body swap vbryanv MKIII Supra 10 05-09-2010 10:01 PM
Jdm Throttle Body Luvs2slide MKIII Supra 1 07-24-2006 07:15 AM
throttle body 87supraguy MKIII Supra 0 02-17-2006 02:40 AM
throttle body boogum7 MKIII Supra 5 12-21-2005 03:01 PM
