Old 10-21-2010, 08:26 PM   #1
seth959ci
seth959ci is on a distinguished road
Default 7mge inefficiencies
after doing some research i still remain puzzled. what about the 7mge makes it so hard to get power out of? (except for that it doesnt have a turbo
Is it the intake manifold or head design? would a front facing intake manifold help? The reason i ask is because im in the beginning stages of a rebuild and i would like to gain around 50 hp if possible... i"ve read that it is harder that it looks.
Any help or mod suggestions will be greatly appreciated
seth959ci is offline   Reply With Quote
Old 10-21-2010, 10:37 PM   #2
bioskyline
as they say, no replacement for displacement. being a 3 liter engine only so much you can gain from non turbo mods. increasing your compression is about the only way you can go if your not adding a turbo. this can be done by using a stroker kit, shaving your head, using a thinner headgasket, boring the block or by shaving the top of the block, or a combo of all the above, but there not cheap. headers and cold air helps aswell. cam upgrades, bigger injectors, bigger throttle body openning or going to ITB, whatever gets more air and fuel in the cylender.
Old 10-21-2010, 11:09 PM   #3
seth959ci
yeah i had those mods in mind... im wondering which is the most cost effective.. i already have a higher flowing exhaust and CAI
Old 10-21-2010, 11:14 PM   #4
bioskyline
http://www.importperformanceparts.ne...s_toyota2.html
Old 10-22-2010, 12:06 AM   #5
Sonyps307
I think with that stroker kit and cams and header and exhaust u should be close to 300hp or pass it that's how the muscle cars did it my dad has a 69 Chevelle with 700hp and it's all motor now with a supercharger pushing over 1000hp
Old 10-22-2010, 12:10 AM   #6
bioskyline
should be but remember that hp gains in n/a motors is greater the larger the motor.
Old 10-22-2010, 12:22 AM   #7
Sonyps307
I know but still the Lexus si350 has a 3.5 motor with 350hp
Old 10-22-2010, 12:40 AM   #8
bioskyline
the lexus motor is alot newer, and as such uses the new twin injection system, and vvt-i. its also 11.8:1 compression vs the 7m at 9.6:1
Old 10-22-2010, 12:47 AM   #9
Sonyps307
7mge is 9.1:1
7mgte is 8.6:1
Old 10-22-2010, 01:02 AM   #10
bioskyline
opps!
7mgte to 7mge conversion help wayzhack MKIII Supra 7 09-07-2010 08:22 PM
7MGE Head Swap 7MGTE87 MKIII Supra 3 03-27-2010 06:39 AM
7mge R154 Manual Trans nnate1228 MKIII Supra 0 03-28-2009 05:59 PM
