Old 10-20-2010, 03:49 AM   #1
zby67
zby67's Avatar
zby67 is on a distinguished road
Default &M-GTE head on the 7M-GE
ok i found a thread on here that talks about it but cant refind it. and was wondering if this is possible? for better air flow and was wondering if i put the Brian Crower Stage 2 Cams on if it will be better or just hinder? and looking for a good description on why i would be bad or if it will work? im not looking to run the GTE distributor just trying to get better air flow by using the vortex rather then the vein air flow.
1986.5 MA70 7M-GE
1987 MA70 7M-GE
zby67 is offline   Reply With Quote
Old 10-20-2010, 04:00 AM   #2
Sonyps307
Well the stock 7mge cams r better then the turbo cams they r more aggressive but if u at putting the stage 2 cams it would be good
Old 10-20-2010, 04:01 AM   #3
t12tninja
t12tninja is on a distinguished road
i was wondering the same thing and you have basically the same year and engine i have thats awesome and same time too i just got mine also
t12tninja is offline   Reply With Quote
Old 10-20-2010, 04:07 AM   #4
zby67
zby67's Avatar
lol i have 2 an 86.5 and a 87 both with the GE engine though the 87 wont start she wants to but wont and so im gunna rebuild and this is what im asking about the head and if it will help with air flow and give better performance.
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 10-20-2010, 04:08 AM   #5
zby67
zby67's Avatar
so then better air flow with the vortex would work and no issues?
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 10-20-2010, 04:33 AM   #6
GTE and GE share the same head. Only difference is one of the camshafts (exhaust, I believe).
Basically, use your GE head and save money
Old 10-20-2010, 04:35 AM   #7
Sonyps307
I'm guessing u can put the swap in vortex I don't know but if the cams have more lift and longer Duration more air flow
Brain crower cams
Stage Description Part# Adv. Dur. Dur @ .050 Lift (in) Lift (mm) Kit# Dyno Shop Status
Street/Strip Specification
Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM spring OK.
Duration Lift
BC0321 264°/264° 220°/220° .336"/.336" 8.53/8.53 BC0320
Race Specification
Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires kit BC0320.
BC0322 272°/272° 226°/226° .342"/.342" 8.68/8.68 BC0320
USDM 7MGTE (’87-’92 MKIII) Stock
256°/256° 201°/201° .297"/.297" 7.54/7.54
Old 10-20-2010, 04:39 AM   #8
zby67
zby67's Avatar
they dont look the same the GE uses the vein looking throttle body well the GTE uses the vortex... and thats what im wondering about if u put the vortex on the GE if you would get better air flow.
7M-GE
http://got-jdm.com/JDM/images/JDM-To...ngblock-90.jpg
7M-GTE
http://got-jdm.com/JDM/images/JDM-To...ngblock-91.jpg
and if its not the head im thinking of can i put the GTE's plentuem i think its called on the GE? and srry if i spelled that wrong and i probably made a complete fool of my self here at any rate lol.
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 10-20-2010, 04:48 AM   #9
Oh, okay. Those are the intake plenum's and the throttle body's.
The GE intake utilizes the Toyota ACIS system (info found here), whereas the GTE intake does not. Without this system, you will likely notice a decrease in power.
For example, 7M Cressidas are rated at about 15hp less than GE Supra's. Cressidas use an intake design more similar to the GTE than the GE.
Old 10-20-2010, 04:50 AM   #10
Here's a Cressida 7M
Head skim requirement? MA70-3.0GT MKIII Supra 11 12-15-2009 06:03 PM
