Old 08-24-2004, 03:39 PM   #1
walter
walter is on a distinguished road
About seven months ago I replaced the engine in my 1989 Toyota Supra Turbo, because the old engine had a blown head gasket. But now when I try to drive it on the street the car will not go over 30mph. The tach revs up but the car dosent speed up. Even changing the gears dose'nt help. It also smokes and idles rough or stalls out when the throttle is released. I dont have a clue as to what the problem could be. Do you have any suggestions?
walter
walter is offline   Reply With Quote
Old 08-25-2004, 07:26 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
at idle does it idle really rough and poke out heaps of black smoke?
when you are attempting to get faster than 30mph are you boosting?
if you are try accelerating very gently thru the gears... try on flat road not hill
if it does any of the above you have a boost leak
if not let us know and we'll go from there
Pics of my build.
Do a diagnostic first!
Old 10-13-2004, 12:37 AM   #3
MA70-1JZ
MA70-1JZ is on a distinguished road
even if he did have a boost leak he would still be able to go faster than 30mph..sounds like the rings are gone
MA70 widebody-1jz conversion with R154, HKS Type S intercooler, Tein HA coilovers, Apexi PowerFC, HKS step one Cams painted in AudiTT Blue
MA70-1JZ is offline   Reply With Quote
Having some Troubles... 87MGE MKIII Supra 4 05-03-2008 08:03 AM
Knock Sensor Troubles!!!! Draftinwitjr3815 Non-Generation Specific Questions 0 03-18-2008 10:16 PM
engine troubles yota_head MKIII Supra 4 02-21-2007 05:58 AM
map ecu troubles turbotaco MKIII Supra 2 01-03-2006 07:41 PM
smog troubles tonster MKII Supra 2 09-24-2005 10:21 PM
