Old 10-13-2010, 08:01 PM   #1
btwilson86
Super Moderator
btwilson86's Avatar
IIRC, FCD is an outdated piece of electronics that isn't necessary with the proper support mods. I've read that it is still potentially damaging to your engine and therefore should not be used.
I'm pretty sure the lexus AFM, 550's, and upgraded fuel pump should allow you to safely boost to those pressures, but I would wait for someone else to confirm what I typed here
Old 10-13-2010, 09:37 PM   #2
fantasma87
fantasma87's Avatar
thanks 86 , i just bought the hks afr , is it good for the upgrade?
ARMY STRONG !!
Old 10-14-2010, 03:15 PM   #3
89ST
89ST is on a distinguished road
Yeah,
That can be a really smart upgrade to have when altering stock boost levels. To accompany it you will want an afr gauge though, this will tell you when you're running lean or rich... or hopefully Stoich! therefore telling you in which direction you need to adjust your afr regulator.
Again you'll also want the upgrades listed above. Those will allow 11-15 psi.
89ST is offline   Reply With Quote
Old 10-14-2010, 06:01 PM   #4
kamikazemkiii
kamikazemkiii is on a distinguished road
To make power you need more fuel and more air, your fuel controller will allow you to change the mixture to a certain but you'll need a wideband to see what your doing, or have it tuned
I have a wideband for 300 shipped
kamikazemkiii is offline   Reply With Quote
Old 10-14-2010, 08:28 PM   #5
fantasma87
fantasma87's Avatar
thanks kamikaze but i will stay with this setting for now. I have to wait until I get home and start working on fantasma and then see what else I need.
ARMY STRONG !!
Old 10-15-2010, 01:17 AM   #6
kamikazemkiii
Just be careful what you do, HG doesnt play
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
fuel problem?.... i think supraluver4life MKIII Supra 6 03-27-2010 06:19 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
How much Boost on Stock Internals? abhattan MKIII Supra 26 02-20-2007 06:30 PM
