Old 10-19-2010, 02:06 AM   #11
907mge
907mge's Avatar
The filter is high on the block and on its side it should drain fairly quick. As long as the filter has oil in it it should be fine.
Old 10-19-2010, 02:12 AM   #12
Sonyps307
Unless it's a turbo and it has that 90 degree thing and screws in the bottom
Old 10-19-2010, 02:22 AM   #13
907mge
907mge's Avatar
Did not know we where talking about the gte. So in that case you should have more oil in it than you state. What does your oil pressure gage read?
Old 10-19-2010, 02:30 AM   #14
Sonyps307
I don't know if it's the ge or gte he never stated I'm just guessing
Old 10-19-2010, 02:41 AM   #15
907mge
907mge's Avatar
What are we talking about ? I am so confused
Old 10-19-2010, 02:58 AM   #16
Sonyps307
I'm not the guy with this problem I was trying to help
Old 10-19-2010, 01:23 PM   #17
johnvin
johnvin is on a distinguished road
ya bro same here there was no oil in there at all like one of you guys had said it must just drain back down in to the block because its located up so high.
i was told that it might be the rod bearings that might be making that really loud knocking noise when it runs ?
johnvin is offline   Reply With Quote
Old 10-19-2010, 01:25 PM   #18
johnvin
well its an 88 non turbo 7mg 24valve 3000,
Old 10-19-2010, 02:32 PM   #19
Sonyps307
Mine had the rod bear knock before I rebuild it but it only knocked between 2500-3000 RPMs and it idle great
Old 10-21-2010, 01:25 PM   #20
johnvin
when i start mine it knocks REALLY loud when it idils and even when you give it gas
1986 Turbo Automatic Transmission Rebuild? professorbob MKIII Supra 2 01-26-2012 01:06 AM
7mgte rebuild questions bradenman1 MKIII Supra 0 05-27-2010 03:36 PM
Replace or Rebuild a 7mge cbrewster MKIII Supra 2 03-19-2009 10:20 PM
To rebuild or not to rebuild that is the question 88supraturbo5speed Non-Generation Specific Questions 6 04-21-2008 04:05 PM
