Old 10-13-2010, 01:49 PM   #1
johnvin
johnvin is on a distinguished road
Default 7mg rebuild kit ??
i found a kit for like 270 for all piston and rings and bearings that sould way to cheap and i dont want something that im going to put in my motor thats not going to last long i just need to fined a rebuild kit
www.jisautoengine.com
that is the web site i found with the kit / what do you think ?
johnvin is offline   Reply With Quote
Old 10-13-2010, 01:53 PM   #2
johnvin
or this web sit i found to www.rpmmachine.com
Old 10-13-2010, 03:37 PM   #3
Sonyps307
JIS is where I got my complete gasket set for my rebuild nice set it came with a metal headgasket to
Old 10-13-2010, 06:02 PM   #4
johnvin
ok sweet so its worth it then ? i would be getting the whole kit the pistons and everything for it
Old 10-14-2010, 02:03 AM   #5
907mge
907mge's Avatar
I paid that much just for the felpro head gasket kit I used. I would not mess around with something as important as engine internals. Make sure you are not gettng something made in china.
Old 10-16-2010, 03:58 AM   #6
johnvin
ok i wont thanks for the tip bro! well i took off the oil filter and there was not any oil in there so maybe its the oil pump. but the wird thing is that i took out the dip stick and there was oil in there
Old 10-16-2010, 10:19 PM   #7
907mge
907mge's Avatar
The oil filter is much higher up on the block
Old 10-18-2010, 01:20 PM   #8
johnvin
so it would not be the oil pump
then ?
Old 10-19-2010, 01:08 AM   #9
907mge
907mge's Avatar
No oil at all?
Old 10-19-2010, 01:48 AM   #10
Sonyps307
I just changed my oil and filter when I drianed it then change the filter it just had a little bit of oil in it unlike some cars oil comes pouring out the oil filter I guess it drains out And my motor is just rebuild with no leaks and new oil pump
1986 Turbo Automatic Transmission Rebuild? professorbob MKIII Supra 2 01-26-2012 01:06 AM
7mgte rebuild questions bradenman1 MKIII Supra 0 05-27-2010 03:36 PM
Replace or Rebuild a 7mge cbrewster MKIII Supra 2 03-19-2009 10:20 PM
To rebuild or not to rebuild that is the question 88supraturbo5speed Non-Generation Specific Questions 6 04-21-2008 04:05 PM
