Old 10-12-2010, 02:39 AM   #1
kingison
kingison's Avatar
kingison is on a distinguished road
That is odd we have had almost identical circumstances. Although I am still driving her around the general area. She sat for the last 3 days and went from cold/max level to cold/min level. I have started the second bottle of lucas stop leak, but I know the inevitable.
Unfortunately, i do not have the means to do the work myself, so I am at mechanic mercy. I'm okay paying 800 for a new installed rack, but when they started talking pump and everything else for a 1900.
Taking her back to Meinkle where I had a rack replacement quote for 650, although he did not visually inspect. If they start talking pump and all when they see it, I guess I am screwed.
Like I mentioned, I personally see only the leak from the one boot area. I think them telling me the hoses and pump is leaking is a hustle.
Good luck with the coolant leak. I hope our situations do not become identical there. But that is pretty damn funny about the floor mat. I couldn't believe it.
kingison is offline   Reply With Quote
Old 10-12-2010, 03:37 AM   #2
Sonyps307
Yea I think the supra with a 7mge is a pretty fast car but everyone looks down on them because they don't have turbos
Old 10-12-2010, 04:10 AM   #3
kingison
kingison's Avatar
I have not driven a turbo, or even a stick MkIII, so I guess that's two strikes against my car. I have no basis for comparison with those.
I'd have to say though I drove my old 03 stock 5-speed eclipse gt the other day, and I am thinkin they are pretty close. Maybe not right off the line, but then again I am not really dragging the supra any. Just pure throttle to floor.
It ain't bad.
Old 10-12-2010, 04:28 AM   #4
Sonyps307
I haven't driven a turbo to but mine is a 5speed and it has a little more pull but mines just been rebuild and has high compression now and I have a header to and I heard with a auto u lost 30-50 hp
Old 10-12-2010, 04:53 AM   #5
kingison
kingison's Avatar
Really? I doubt the auto is that poor. Have you driven one? 2nd gear has a pretty lunge to it, and other than a quicker line start, I would only see a 5 speed with a slight advantage. Not sure if I would place the difference that high. Seems to perform as listed stock around 200 hp.
I'd like to try out a 5 speed.
Old 10-12-2010, 04:57 AM   #6
Sonyps307
Yea the 5 speed is fun to drive
Old 10-13-2010, 01:21 AM   #7
rjSupra
rjSupra's Avatar
rjSupra is on a distinguished road
Default my 2 cents on the screamer
I'll weigh in here,
my turbo 1988 is a weak little kitten. very unimpressive.
BUT when you spool up the turbo and it hits, it is a pure screamer and drives your back into the seat like almost no other car I've been in... it's pure grins and giggles... way more exciting feel than say my Acura Integra and other much quicker cars. It 'feels' a lot faster than a Porsche Boxster for example. Don't know what the numbers would say, but comparatively, that Boxster is a bore. (I think the tires are too grippy for it's own good).
I also hear the stock non-turbo feels faster and stronger by a measurable amount if you compare it to the turbo and don't have the turbo boost up. There's different compression ratios etc... that make the N/A car feel faster at low revs, low torque etc... But again, I have to guess the N/A can't really compare to the turbo on boost or full boost. My two cents. And by the way, I am driving an auto. (I wonder a lot about the 5 speed - I got sold all the parts to convert it with the car, but am a) 'chicken' to convert at the moment, b) have to use in heavy traffic until I have another daily driver c) dealing with some other significant mechanical problems that have the car sidelined and un-driveable until I repair them (mystery top front motor coolant leak, and very bad PS fluid leak for example).
88 Supra 7M-GTE Turbo, TEMS, Targa stock
rjSupra is offline   Reply With Quote
Old 10-13-2010, 03:01 AM   #8
Sonyps307
My non turbo 5speed was just rebuild and now has higher compression then stock it pulls pretty good and the non turbo also has more aggressive cams then the turbo
Old 10-30-2010, 07:33 PM   #9
Metaphysico
Metaphysico is on a distinguished road
Actually the na has the same cam lift as the turbo its just the na exhaust cam is timed a little different, I have not put a degree gauge on each one to check but you can visibly see a slight difference in how they are clocked on the cam.
The na also has a different geared rear end and more power and torque on low end than a turbo does. So off the line the na is more fun but after 5 seconds when your up to full boost and going good the turbo just pulls and pulls then pulls some more. Just gotta watch out for wheel spin going into second and third gear and fourth gear if you have more than stock boost.
I love my na for a good nice reliable car but I also love my turbo to haul ass and take names.
Metaphysico is offline   Reply With Quote
Old 11-02-2010, 05:35 AM   #10
bioskyline
bioskyline is on a distinguished road
i dont know, my auto still flys when you punch it. the beauty of a an auto is no turbo lag changing gears
87 silver turbo targa, bone ass stock (for now)
bioskyline is offline   Reply With Quote
question about the stock BOV on a MKIII Turbo TehEl1te Non-Generation Specific Questions 3 08-23-2009 10:20 PM
MKIII Headlight Problem Supra275 Non-Generation Specific Questions 4 09-05-2008 09:06 PM
