Old 10-06-2010, 03:40 PM   #1
SRA
SRA is on a distinguished road
Default steel reinforcement
hi, im new to the forum but im in need of help im about to purchase a 87 turbo supra and there is a lil bit or rust right under the radiator support. i have been reading that is common to get rust on the steel support is the radiator support the same or is it something different n if so does it take much to fix? thank for your help.
SRA is offline   Reply With Quote
Old 10-06-2010, 04:33 PM   #2
Grandavi
Grandavi's Avatar
If your just buying the supra now.. I would read a lot..
Check the wheel wells very closely (you are in Florida, so rust isnt going to be as bad of an issue as up North.. depending where the car came from). Also, put your hands in the rear quarter panels (you can access from inside the hatch) and feel the bottoms.. if full of dust/moisture.. your going to have to look at everything for rust. Dont forget to pull the spare tire out and see the condition of its holding area as well. Water will pool there if your brake light seals/hatch seals arent working perfectly.
As for the rad support, I have never personally seen rust there except when the metal is kinked. I will have to let someone else answer that part.
Just as a further note.. I went to buy a 90 Supra for 2500, and ended up buying it for 800 after I did a full inspection (for body filler etc..) as these vehicles have very well known areas where they age faster.. Doors, Quarter Panels (above the wheel well), mud flaps and trim, body trim, brackets that hold the bumpers on, etc...
Do as much reading as you can prior because it will save you a lot of time after.
Old 10-06-2010, 05:14 PM   #3
SRA
thanks a lot for your response, the car seams like is good shape but i was over heating so im thinking that's going to be the valve cover gasket. but besides that body is im great shape n the interior is nearly perfect but the best part is that he is only asking 1000 so im going to try to get it for 800.
Old 10-06-2010, 06:24 PM   #4
Grandavi
Grandavi's Avatar
Valve cover gasket wont cause overheating... you just entered a very large area of problems... lol
1. Supra's are notorious (MKIII's) for bad head gaskets
2. 7MGTE's run very hot already... if they overheat.. your gonna have trouble unless its fixed fast
3. the list is long and endless without seeing the car.. but with a MKIII 7MGTE, I always assume a bad headgasket exists. Look for the signs (smell antifreeze in the exhaust, milky oil, coolant scummy, etc...)
At 800.00 if the car is in good shape.. I like it (bodywise), but be aware, unless you are mechanically inclined and have tools, you may be buying a car that wont be drivable in a short while. I would have a mechanic go over the engine first.
READ THIS!
http://www.toyota-supra.info/forums/supra-faq/3296-buying-supra-what-to-know-first.html
It has a lot of good tips.. read the whole thread though.. not simply the first portion.
Old 10-06-2010, 06:48 PM   #5
SRA
http://okaloosa.craigslist.org/cto/1986572733.html this is the car, and thanks a lot once again. i just got done looking over the thing that u have planned for your car and it looks like is going to b a beast.
Old 10-06-2010, 07:08 PM   #6
I wouldn't pay more than $500 for a car that I can't start up and listen to. The seller says it needs a head gasket replaced, but it could also have bad rod or main bearings. Driving a car with a bhg for too long causes the antifreeze in your oil to act like sand, and sand will kill your bottom end in no time.
Old 10-08-2010, 02:53 AM   #7
painknight
painknight is on a distinguished road
Default Radiator support.
If your still wondering about that, do you mean that the bottom of the support has rust or do you mean under the radiator has rust. If it's the bottom, then it prolly just got scraped by something. Chances are that it won't need replaced. Just hit the rust with a wire wheel or coarse sandpaper, then cover it with rust converter. If it's so bad it does need replaced (You'd be able to knock the price down with that as well I think), well, my uncle turned a dead deer into 400 peices of dead dear in an sc400, and him and his dad (Both mechanics, not body guys) were able to replace it on their own.
Good luck on getting the car.
1987 Supra 7m-ge, manual trans, LSD.
Sorry the banner sucks I made it with paint.
painknight is offline   Reply With Quote
Old 10-08-2010, 02:55 PM   #8
Metaphysico
Metaphysico is on a distinguished road
Head gasket is going to cost a good bit, plus you are going to want to get it machined and get a metal head gasket and arp studs or bolts. The other thing is its harder to put a car together that you didnt take apart then it is to take one apart and repair yourself. Also a shop will take this into consideration and will charge you more for repairing it. Even though there is less work because some of the stuff is off, it is more work to figure out how everything goes back on when they didnt take it apart. Some places wont even touch it if its apart. And of course you could have other issues with the car, so in short if you can't do it yourself and don't want a car that is going to need a lot of care don't get it. Supras are great cars but they need work due to the age and mileage.
Metaphysico is offline   Reply With Quote
Old 10-14-2010, 02:23 PM   #9
SRA
so i ended up getting the supra, and im currently looking at head gaskets i have come accross a few that im interested in but just recently i came across a felpro, has anybody heard anything good or bad about it?
http://www.autozone.com/autozone/par.../N-iivy5Z8znn3
or should i just go with a hks?
Old 10-14-2010, 03:28 PM   #10
Grandavi
Grandavi's Avatar
I really dont want to answer that because its very involved. There are many threads discussing Head gastket replacement and although in my head its very simple, when I go to do it, I realise that its much more than a head gasket replacement. If you are just looking to redo the headgasket, I would go with OEM. If your planning on extra power, I would do a lot more planning. Totally depends on the engine and what you see in the engine bay, plus what your final plans are with the vehicle.
Going to work on upgrading the turbo, upping your boost, adding a 3" exhaust (highly recommended), replacing all the old rubber or whatever else it needs, doing the valve seals, etc.. etc... all this plus your budget are the factors. You really want to think this through solidly and do it once. If you are going with a thicker/metal headgasket, your going to have to be a bit more careful with the head/block prior to putting it in.
Its an excellent motor when its done properly, but you should start with what your final goal is (just get the damn thing running and daily driver or "lets get this puppy really moving...")
Plus, the valve cover gaskets are a bit of joy, so you should research those and perhaps do those slightly different as well. The weak point in the valve covers is the "screws" that hold them on. They need to be torqued correctly (ft/ins not lbs) and invariably leak into the galley when done incorrectly or not retightened. Some people have a lot of good suggestions regarding that. There is also a technique for sealing the spark plug galley to prevent oil from pooling in it if they do leak.
Not trying to scare ya or frustrate you, but if you do have the time, I would plan it all out first. Its not like a typical rebuild that I have done in the past. If you cant find the information, I can see if I can find all the links I have found in the past discussing the various areas of interest.
to me, the key is .. do it once.
Stainless Steel Lines Conversion; 7MGTE bryanf89 MKIII Supra 4 09-29-2010 04:47 AM
ct12a steel wheel old dude Non-Generation Specific Questions 2 03-04-2007 08:39 PM
SHitty steel rims to fit on a supra shezza from the cressida forums Non-Generation Specific Questions 1 08-04-2005 08:45 AM
stock ct-12a turbo mod to steel wheel daiagaru2 MKIII Supra 2 07-31-2005 06:02 AM
