Old 10-06-2010, 04:27 AM   #1
jcastro
Default Can I do this?????
I know there are threads about 1jz swaps but I cant find the answer I was looking for. I recently wanted to do a 1jz swap but was so confused over the wiring. I found a supra with a 1jz swap, the same exact year as mine. However the body and interior is kinda bad, and it is auto. I was wondering can I do the swap and use the wiring but keep my trans. If I cant what should I do. Thanks for your guys help in the past and I relay appropriate all the help you guys give.
jcastro is offline   Reply With Quote
Old 10-06-2010, 02:13 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
Yeah u can. U will have to bypass the nutruel switch. and get a r154 transmission belhousing. About 400 bucks. Plus u would need a flywheel which is about 300 bucks. Plus a new clutch 250 which I'd recomend for any swap.. I didnt and mine is now slipping. Never use a used clutch.. so it really wouldn save u much money. If your worried about the harness just send it to Dr tweek.
And be aware that harness still may not plug into your car depending if they made plug adapters or hard wired the jza70 plugs on the chassis... pm me your email address and ill send u pics of my harness and what I did to it.. I did it in a way I didn't cut my chassis plugs or harness plugs. just had to extend it. It really isn't that hard at all just time consuming. It took me a 3 day weekend to do just the harness.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 10-07-2010, 01:12 AM   #3
jcastro
Ya true but I can get this car for 3gs and take out the 1jz put my 7mgte and get it running and sell it. Then i plan to just plug and play with my car and the 1jz.
Old 10-07-2010, 01:36 AM   #4
Travis89Turbo
In a perfect world that would work. But I have 50 bucks on it that he cut the chassis harness and put the jz plugs on it. So the 7m won't plug back up to those plugs. nor will the jz plug into your car. But it depends how the harness was modded and the quality of the job done. It would be hell to trouble shoot an extended harness as there is over 250 locations it could go wrong. Even just a break in the wire would suck to find. With out cutting and soldering either the harness or your chassis it pribably wont plug in.. UNLESS he put the 7mgte plugs on the jz harness then it would be pretty smooth. If the harness was done properly.. basically the same thing u have to do any route u go. I paid 3g for the front clip and it was a manual.. cuz your looking about 1g for parts to convert the jz to manual..
stock 2jzge
Old 10-08-2010, 06:08 PM   #5
jcastro
haha Fuck my life and thaks for those pics ya ima say fuck it and due it your way and hopefully get it done with the help of friends on supra forms your so right i would be taking a chance on the whole thing might aswell put the work in and do it right
Old 10-08-2010, 06:12 PM   #6
Travis89Turbo
Spoken like a wise man
stock 2jzge
