Old 09-27-2010, 04:30 PM   #1
donbrown92
donbrown92 is on a distinguished road
Default 1989 mk3 supra tail light problem
So on my supra when I use the brake, the lights come on but when i take my foot off of the brake no lights come on.
Help? fix?? advice?
Ima car noob.
donbrown92 is offline   Reply With Quote
Old 09-27-2010, 08:45 PM   #2
Sinistral
Sinistral is on a distinguished road
"...when I use the brake, the lights come on but when i take my foot off of the brake no lights come on."
Unless you're leaving something out, it sounds like the tail lights are doing exactly what they're supposed to do.
Sinistral is offline   Reply With Quote
Old 10-01-2010, 03:06 AM   #3
dannydavi
dannydavi's Avatar
lol yeah that's a pretty good example of exactly how brake lights work... I on the other hand have the opposite problem and would love a solution! my tail lights when my lights are on are really dim and when i push my brake pedal the tail lights and brake lights don't work at all. The hatch brake light works but not the two below. Also when I push the brake pedal when the car is off I notice my stereo lights lighting up :s... and then to top it all off at the same time these went out my dome lights on the interior don't work. Any suggestions would be greatly appreciated. I have already checked the obvious fuses and replaced all bulbs. Not trying to steal his thread, but perhaps this is what he was getting at...
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 10-01-2010, 06:19 AM   #4
Busted Knuckles
Busted Knuckles's Avatar
Check the grounds. If the ground circuit at the tail lights goes bad, the brake lights will use the double filament to seek ground through the parking lights, powering up the parking light circuit and the dash light circuit.
Old 10-01-2010, 10:31 PM   #5
chopsticks
chopsticks's Avatar
chopsticks is on a distinguished road
i had the same problem. If you take off that interior piece that you have to take off to change the bulbs and look under the light bulb retainer there is a little yellow box. That may be bad. I have to pull over when i notice my brake lights arnt working and have to jiggle that box around. mine has a short. But i dont know where to pick a new one up at??
chopsticks
chopsticks is offline   Reply With Quote
Old 10-02-2010, 12:51 AM   #6
Busted Knuckles
Dealer. But, you could open the box yourself and re-solder any broken solders.
Old 10-02-2010, 05:44 AM   #7
dannydavi
dannydavi's Avatar
I have already opened up that yellow box and all is good in there. Looks in perfect condition. And as far as the grounds go... where would one find those?
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 10-02-2010, 07:27 AM   #8
Busted Knuckles
You need a multimeter, and check for resistance between any of the white with black stripe wires (ground circuit) and a know good ground. You should be getting 'infinite' ohms, meaning no resistance. Zero ohms means a break somewhere, and anything else means a corroded ground connection somewhere causing a resistance.
Old 10-02-2010, 07:35 AM   #9
btwilson86
Super Moderator
btwilson86's Avatar
Close, you actually have it backwards though. 0 ohms means almost no resistance, meaning a good conductive wire. Infinite ohms (often represented with a "1" at the beginning of the display on a digital multimeter) means that the 2 reference points are not connected to each other electrically
Old 10-02-2010, 09:59 PM   #10
chopsticks
chopsticks's Avatar
Well i have already opened it and everything looked fine. A buddy of mine told me that is a common problem with the brake lights.
chopsticks
Tags
1989, brakelights, fuse, supra, taillights
1989 Turbo Supra FS 95% complete TehEl1te Buy/Sell Cars 8 06-15-2010 08:26 PM
My lucky find: 1989 Toyota Supra Turbo seken-cole Show n Tell 7 05-23-2010 10:55 PM
Need advice with BHG on 1989 Supra Turbo redsupra89 MKIII Supra 2 05-21-2010 11:40 AM
1998 Supra Check Engine Light SupraLady Non-Generation Specific Questions 2 12-15-2004 11:39 PM
