Old 09-22-2010, 03:14 AM   #1
suicidal
suicidal is on a distinguished road
Default 7mge to 1jzgte swap mounting
what will i have to do to mount the 1jz in my 89 supra? would i be able to use the factory mounts or do i need to make custom mounts? i wanted to ask before i bought the motor and such to realize i screwed up.
tokico shocks, drilled rotors, race pads, stage 2 clutch, full exhaust, custom intake (filter and pipe)
suicidal is offline   Reply With Quote
Old 09-25-2010, 03:22 AM   #2
suicidal
any in site would help. also do i have to get a new drive shaft? never done a swap like this before so help me out.
Old 09-25-2010, 04:48 AM   #3
86.5 7MGE
86.5 7MGE's Avatar
If you search in the forum you will find your answers as I am sure that they have been asked before. As with any swap I'm pretty sure that you would have to change out your engine mounts they do make them for the conversion and plus I'm sure they are still the original ones so they might be prone to cracking or breaking with added hp; it never hurts to do them while you have your engine out anyways.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 09-25-2010, 06:32 PM   #4
Travis89Turbo
Travis89Turbo's Avatar
I have got a 1jz in my 89 they are the same mounts but chances are that they will be worn out. Buy a set from driftmotion for 130 bucks. Make aure your 89 has the round style mounts by getting underneath of it and looking... if u have any questions I have a lot of answers and photos of my swap... check out this link it should answer 95% of your questions http://www.supraforums.com/forum/sho...d.php?t=292754
Also check this one it goes over all the wiring.
http://1jz.com/
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
7MGE swap supraluver4life MKIII Supra 6 05-06-2010 09:01 PM
7MGE Head Swap 7MGTE87 MKIII Supra 3 03-27-2010 06:39 AM
Question about swapping from a 7MGE to a 1JZGTE Supraman24 MKIII Supra 13 08-23-2009 10:25 PM
7MGE to 1JZGTE engine swap help please! seek102287 Non-Generation Specific Questions 2 07-02-2007 12:57 AM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
