Old 09-22-2010, 12:44 AM   #1
borgerding
borgerding is on a distinguished road
Default Engine Swap
Can you put a twin turbo in any Supra or will it only fit in certain years?
borgerding is offline   Reply With Quote
Old 09-22-2010, 02:30 AM   #2
Travis89Turbo
Travis89Turbo's Avatar
Depends. Give me an example? Ultimately any motor can go in any car with enough modification and money$$$$$$$ You can put a 1jzgte in a mkiii and mkii.
2jz will fit in mkiii but u have to beat the hell out of the firewall most people swap to a single. not sure bout the mkii with a 2jz and stock twins all the ones i have seen have been single turbo, a lot to do with the fact u can make more power on a single. But me personally like the twins especially for street driving which is the main purpose of my car. i did the 1jz swap myself for more then one reason.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 09-27-2010, 04:17 AM   #3
borgerding
Do you have some pics to post of your car?
Old 10-08-2010, 05:48 PM   #4
Metaphysico
Metaphysico is on a distinguished road
The 89+ cars will fit the 1j and 2j because the sub frame and motor mounts are different, pre 89 not sure what all has to be done to fit one. Either way its a lot of work and money, unless you have say $4000 don't even think of doing a swap.
Metaphysico is offline   Reply With Quote
Old 10-08-2010, 06:10 PM   #5
Travis89Turbo
Pm me your email address ill send ya pics. My cell phone won't let me post pics on the forum.
4k will get u a 1jz swapped in. But the 2jz has a different oil pan with the hump in the oppisite location. So 2jz swap add about 1k to your build plus the 2jz stock twins don't fit without mod to your firewall.. the whole crossmember has to be changed to a 89+ if you have a pre 89
stock 2jzge
engine swap.... hiaburi Non-Generation Specific Questions 3 05-11-2008 04:54 PM
engine swap ! NYTRYDR MKIII Supra 13 08-11-2007 05:37 AM
JDM swap, now engine light, please help christutecky MKIII Supra 0 08-10-2007 07:49 PM
7MGE to 1JZGTE engine swap help please! seek102287 Non-Generation Specific Questions 2 07-02-2007 12:57 AM
Need advise on engine swap. 3RD STRIKE MKII Supra 1 06-29-2007 06:49 PM
