Old 09-20-2010, 12:57 PM   #1
Default Valve covers
gona paint them this weekend.
was thinkin of black with another color for the writing. lets here some ideas...
car is white.
Old 09-20-2010, 05:32 PM   #2
Red would jump out, but white would be good too since it'll tie the exterior color in. Are you planning anything else to be a different color (like ignition wires, brackets, timing cover, etc)?
Or you can paint it black, and polish the letters back to aluminum. THAT would be nice
Old 09-21-2010, 04:33 AM   #3
that sounds nice,
what would i use to polish it back to aluminum? steel wool, or fine sand paper?
Old 09-21-2010, 05:10 AM   #4
I'd use a low speed dremel tool or something similar to clean the paint of of the area you want polished, then using sandpaper sand it by hand building up to a reallllly fine grit.
I once had a set of 7MGE covers that I sanded smooth ending with 1000 grit paper, they looked damn nice. No more casting pits or marks of any kind, but still weren't to that shiny polished look. However, they were almost there.
I'd guess you'd want to reach 1500 grit, and then use high temp clear coat paint to give the whole cover a nice, glossy finish.
You'll probably need to use a clear adhesion promoter for the sanded parts. I believe Duplicolor makes the adhesion promoter and high temp clear coat.
Old 09-21-2010, 03:19 PM   #5
yea that would be nice. --> green7mgte likes this <---
Old 09-22-2010, 03:07 AM   #6
MJG
MJG's Avatar
I have a white car and I painted the cam covers with a white engine enamel.
Nothing fancy, just clean.
If you wish, I can snap some pictures.
Oh..Very easy to keep clean...
Old 09-22-2010, 05:51 AM   #7
+1 on the pics, always nice to see the little things people do to dress up their engine bay. Wish I still had some pics of the covers I sanded down...
Old 09-23-2010, 02:17 AM   #8
MJG
MJG's Avatar
Default Engine bay photo's
Attached are some photos.
Name:	Full Front.jpg
ID:	3441   Click image for larger version
Name:	R. Close up.jpg
ID:	3442   Click image for larger version
Name:	L. close up.jpg
Old 09-23-2010, 03:56 AM   #9
Dang, I like it. Doesn't jump out at you, it's a nice subtle touch up. Not to mention the clean engine bay all around tying everything up real nice
Old 09-23-2010, 02:11 PM   #10
dam dude.
didnt think white would look so nice, is it flat or a gloss i cant even tell...
youv got one of the nicest engine bays i ever seen on a mk3...
think im gona go with either black or white, and ill probly either color or sand the letters out.
Where to add RTV sealant to valve covers on 7M engine trevor217 MKIII Supra 7 05-02-2010 05:53 PM
Bad Proportioning Valve? georides Non-Generation Specific Questions 5 03-05-2009 03:34 AM
