Old 09-13-2010, 04:02 AM   #1
Conga1991
Default Car wont turn over after swap!
Alright so first thing is details. I just swapped a 7mgte into my 7mge supra. I have the same year ecu with harness and motor but my body is 88 which doesnt make a difference since pre 89 are the same. The harness was for a automatic and decided to use a R154 tranny. So I researched how to bypass the nuetral system and spliced the two wires off of one round plug together.
Things I havent done yet is put the Turbo tachometer in yet and thats the only thing. I used the original NA starter and figured I didnt need to change that out. I also got a 100 amp fuse for the alternator, is that the right one or is it a 80 amp? originally there was just a wire connecting to each side to get power to the alternator. There is two small plugs from the harness next to the ecu that dont have a place to pug into, one is black and the other is yellow. And I havent conneted 3 wires that go to the water neck, they are the ones that slide onto the metal like the fan shroud and coolant temp switch. Other then that everything is connected.
There is power because I replaced the battery the other day.
Any and all sugestions are welcome to what the problem might be?
Old 09-13-2010, 12:53 PM   #2
what happens when you turn the key??
plz explain...
because i pulled a 7m engine recantly and forgot some starter wires...
Old 09-13-2010, 06:23 PM   #3
Conga1991
When I turn the key to turn it over theres one click noise coming from where the ecu is, which was kind of strange and I couldnt pin point where exactly where it was coming from.
Also the fuel is going cuz I hear a spray and I have a little fuel leak which Ill fix as well as a small coolant leak on my floor.
Old 09-13-2010, 06:26 PM   #4
916MKIIIx2
you might want to unplug the fuel injection until the starter atleast starts kicking, so you don't flood the cylinders. Take a vantage or something to the starter wires and make sure you're getting power, you can do an amp test by cranking the started while having the leads in the proper position on the started case and on the big ass wire bolt attached to it, i think thats right atleast its been awhile.
Old 09-13-2010, 07:02 PM   #5
Conga1991
okay. when you mean by unplugging the fuel injection you mean each wires to the injectors right?
Old 09-13-2010, 07:49 PM   #6
916MKIIIx2
EFI fuse should do it
Old 09-13-2010, 09:44 PM   #7
Conga1991
What do you mean the efi fuse should do it?? explanation please?
Old 09-13-2010, 10:21 PM   #8
Travis89Turbo
Travis89Turbo's Avatar
Fix your fuel leak before going any farther.. safety first. Pull the little wire from your starter and have someone turn the key and check for voltage. Again while wire is unhooked from starter. Don't pull the efi fuse or u will lose power to your ecu the main brain of the efi system and that's why its powered from the efi circuit. Check your connections on battery and make sure your ground is hooked to the block below intake manifold. Let us know
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 09-13-2010, 10:23 PM   #9
ochowdero
your EFI fuse is for your injectors, a bad one basically tells your injectors to stop working and then in return your car is starving for gas. a good one just does what its spose to..
you have 2 fuse box, my EFI fuse is located under the hood on the drivers side, its a 15a and is labeled "EFI"
check the one under your hood, if not there, check the one in your car by the drivers kick panel
once you find it pull it out, if its good keep it, if not go get a new one..
then just turn your ignition to see if you get acouple clicks from the starter..nothing? then take a amp to see if your even getting power to it...
maybe you missed wires..
check the amp level any way, i think you should have 1.5? idk im not sure...
tell me if you get it working..
Old 09-14-2010, 12:26 AM   #10
when i did the swap same clicking happened it was wierd.
A.starter was hooked up wrong
B.battery was dead (check that you have proper voltage.)
you need air fuel and spark.
your missing one...
headlights wont turn off after swap 89supra884 MKIII Supra 7 04-19-2010 03:24 AM
NA->T swap and convertion questions 5+4=9 MKIII Supra 6 03-02-2006 02:11 AM
