Old 09-13-2010, 12:50 PM   #11
what i would do is drill a 4 inch hole right behind your right headlight. and send your w/e style filter under, you may need to drill a second hole to get into the bumper, but when finished your intake is in your bumper.
Old 09-14-2010, 02:01 AM   #12
You don't need to drill anything there's a hole already there which the stock air box breathes through. A 3" 90 degree pipe will put the filter out of the engine bay and right below the headlight. You'll need a cheap AFM adapter (can be had off eBay for around $10 including shipping), a couple silicone couplers, hose clamps, one piece of aluminum pipe with a 90 degree bend and possibly one straight piece, and a "universal" filter with a 3" opening. If you really want to go all out wrap the piping that's in the engine bay with heat wrap or get it ceramic coated.
Old 09-14-2010, 02:05 AM   #13
not in my mk2...
gettin the 2 mixed up again...
Old 09-14-2010, 02:34 AM   #14
I figured that must be the case.... It's been soooo long since I've looked under the hood of one I can't remember at all how the intake is setup.
Old 09-14-2010, 03:19 AM   #15
pretty much the same, but diff.. lol
off topic. there is a mk2 with a jdm 1jz tt for 3k near where i live... but im broke... i want it sooo bad.
Old 09-14-2010, 03:28 AM   #16
Sonyps307
Pipe it down into the front bumper like a intercooler or a ram air I seen a pipe called a pre-intercooler pipe On http://www.siliconeintakes.com it had fins on it like a heat sink and lowered the temp. Alot just from one pipe
Old 09-16-2010, 04:28 AM   #17
86.5 7MGE
86.5 7MGE's Avatar
Default Suggestion
What I did was just use some after-market piping from a different car and fabricated my own it looks nice and Cre has seen my work; it's CAI and I have my cone filter behind my bumper with a shield on it to protect from direct splash or rain; now just have to fabricate a front diffuser to better protect it from puddles and find a piece of piping to fit in to replace my big sensor box.
Name:	2010-05-26 16.29.37.jpg
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 09-16-2010, 04:31 AM   #18
ochowdero
yeah im gonna start fabricating mine shortly
alot of other things on my mind hahha
Old 09-19-2010, 05:30 PM   #19
Green7mgte
Supra Forum Moderator
if its a turbo.. your gonna get all the air you need anyhow. I would concentrate on bigger injectors / intercooler and turbo.. but if not.
its not really going to make a difference besides looking cool.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
warning light that looks like a dome or filter? colo288 MKIII Supra 11 03-19-2010 08:06 AM
Product Review: AEM Dry Flow Filter 3" by 5" mkiiisupra Shops & Part Reviews 4 01-15-2010 02:15 AM
K&N Air Filter D_Train MKIII Supra 6 01-04-2008 07:27 PM
1991 Non-Turbo Supra: Use of K&N air filter to boost hp and mpg? unkymurch Non-Generation Specific Questions 2 04-02-2007 04:36 PM
