Old 08-23-2010, 06:27 PM   #1
supraluver4life
supraluver4life is on a distinguished road
Default machining mistake
So I was reading up some build threads today and saw that when the block was being machined it has to have the timing belt cover on it because the head actually rests on it. I didn't have this done and now I feel like an idiot.... I think so lol. What can or should I do now. The block had 0.013" taken off so there is a 0.013" difference between the block and the timing belt cover. I need to know what I should do
Thank you
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
supraluver4life is offline   Reply With Quote
Old 08-23-2010, 08:26 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Unfortunately the gasket and head overlap the top of the timing belt cover, so the block and cover need to be at the same level. What you read is correct, the safest way is to bolt the cover back on and have it machined down to the same height as the block.
PS; Have you put the block back into the Supra ?
Old 08-23-2010, 11:10 PM   #3
so the same metal timing cover piece should done when doing the head aswell?
doing my head in a couple weeks and wouldnt mind knowing if i need to keep the timing belt cover on
Old 08-24-2010, 04:31 AM   #4
The upper cover isn't a huge concern, there's enough slack in the screw holes to account for taking a full millimeter off the head. The lower cover is the deal breaker.
Old 08-24-2010, 05:53 PM   #5
depami
ID:	3351 + Click image for larger version
Denny
82 5 sp 928 - Guards Red
92 FlightCraft 18 XLT
94 1200 Sportster
01 F150
Old 08-25-2010, 03:33 AM   #6
Originally Posted by depami View Post
ROFL
I don't know whether to laugh or ban you..... well, I guess I already answered my question.
Seriously though. Blindly attacking it with a file or angle grinder is a HORRIBLE idea.... a belt sander would at least assure you of a more even surface. I'd attack it with a lapping plate with a piece of 320 sandpaper laminated to it and then some diamond lapping compound of decreasing grits to take it down (In fact I've had to do so in the past).
Old 08-25-2010, 03:52 AM   #7
supraluver4life
so can i just take a belt sander to it? like seriously because the shop said they cant do that. is there an issue with it if the timing belt cover gets more taken off than the block?
+300rwhp
Old 08-25-2010, 05:40 AM   #8
ROFL
i was gona say something, but i didnt want to dignify him with a response...
Old 08-25-2010, 05:48 AM   #9
depami
It has been a while since I changed my head gasket (about 10 years ago at around 142,000 miles) but I don't recall any issues with the timing cover. However, I did not take anything off the block.
But I did shave a little off of the head!
Does that surface seal combustion, coolant or oil? If so, than proceed with care. Otherwise this should work!
Denny
94 1200 Sportster
01 F150
Old 08-25-2010, 11:32 AM   #10
Bill UK
AEM EMS
Bill UK's Avatar
That aperture between the block and the rear cam cover leads to a drain hole into the sump, as you will see if you put the gasket on top of the block there are two oil gallery’s that line up at the front. As you are only removing .013 thou and the cam cover is only cast ally, I would do as cre suggested.
Aluminium piping. Is it a mistake or not? azerty MKIII Supra 13 04-30-2008 08:33 PM
