So I was reading up some build threads today and saw that when the block was being machined it has to have the timing belt cover on it because the head actually rests on it. I didn't have this done and now I feel like an idiot.... I think so lol. What can or should I do now. The block had 0.013" taken off so there is a 0.013" difference between the block and the timing belt cover. I need to know what I should do
Thank you
Cusco front, Tein Rear coilovers Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi +300rwhp "Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy" |
AEM EMS
Unfortunately the gasket and head overlap the top of the timing belt cover, so the block and cover need to be at the same level. What you read is correct, the safest way is to bolt the cover back on and have it machined down to the same height as the block.
PS; Have you put the block back into the Supra ? Last edited by Bill UK; 08-23-2010 at 08:29 PM. |
so the same metal timing cover piece should done when doing the head aswell?
doing my head in a couple weeks and wouldnt mind knowing if i need to keep the timing belt cover on
1984 supra - 1uzfe - w58 - 4.10 - 1 piece aluminum shaft. |
The upper cover isn't a huge concern, there's enough slack in the screw holes to account for taking a full millimeter off the head. The lower cover is the deal breaker.
Denny 82 5 sp 928 - Guards Red 86.5 auto 928 - Meteor Metalic - No Rub Strips 86.5 5 sp Supra SR/SS - Amethyst 92 FlightCraft 18 XLT 94 1200 Sportster 01 F150 |
#6 | |
![]() I don't know whether to laugh or ban you..... well, I guess I already answered my question. Seriously though. Blindly attacking it with a file or angle grinder is a HORRIBLE idea.... a belt sander would at least assure you of a more even surface. I'd attack it with a lapping plate with a piece of 320 sandpaper laminated to it and then some diamond lapping compound of decreasing grits to take it down (In fact I've had to do so in the past).
| Aluminium piping. Is it a mistake or not? | azerty | MKIII Supra | 13 | 04-30-2008 08:33 PM |
