Old 08-15-2010, 03:27 PM   #1
Default auto to manual swap.
so i finished my auto to manual swap about a week ago on a 1986.5 N/A
put in a 1987 w58 and older mk2 clutch and flywheel.
but i think my slave cylinder may be done for. it wont shift into gear when the car is on.
i looked under there and got a friend to pump the clutch it doesnt look like its moving enough...
i went ahead and purchased a brand new slave, and i have yet to go pick it up and install it.
just wanted a second opinion on the matter. im hoping that its not my master.
what do you all think clutch master or slave??
(extra info on parts used:
1987:
w58
w58 hard line
w58 master and slave both sat for a year...
clutch pedal from 87 and my pedal hits the carpet!
and brake pedal from 87)
please guys i need a second opinion!!!
thanks in advance...
Old 08-15-2010, 04:18 PM   #2
Have you bled the system a second time?Is the pedal adjusted properly? Slave and master are easy to replace, but I'd still hope that it's just air in the line or one of the cylinders.
Old 08-16-2010, 02:53 AM   #3
i replaced master and slave today and bled a couple liters through the lines, and only gained a little better shifting, i have come to the conclusion that the clutch pressure plates are that bad.
infact im positive my old slave and master were perfectly fine.
but yes i put a really bad clutch in because i cant afford anything right now.
Old 08-20-2010, 07:54 AM   #4
gloreboy89
gloreboy89's Avatar
gloreboy89 is on a distinguished road
how much did i cost you to do the conversion. i also have a auto wit a 7mge engine which i would plane to keep in if possible.
too lazy to find a funny quote, buuuutttt off the top of my head. "life always= how well you treat your car, put crap in ur car, then car breaks down, then miss important meeting, or work which just so happen u cant miss another day or ur fired... and end up with a crappy life.
driving an '88 supra
gloreboy89 is offline   Reply With Quote
Old 08-20-2010, 12:19 PM   #5
master and slave cylinder was around 120 all together new.
i still need a clutch setup wich is gone be around 300
a w58 i already owned, but could be purchased anywhere from 100-500 dollers
clutch and break pedal 40 dollers
the driveshaft i already owned not sure its worth but not much im sure.
auto to manual tranny swap sd88supra MKIII Supra 10 11-24-2009 06:25 AM
93 supra auto to manual swap nzskate MKIV Supra 2 07-22-2008 05:44 AM
What is involved (all parts, labor, price) in auto to manual swap??? the t3d MKIII Supra 1 01-18-2007 03:01 AM
MKIV auto to manual swap?? awd4g63tsi MKIV Supra 0 10-24-2005 08:46 PM
