Old 08-09-2010, 03:03 PM   #11
Sonyps307
http://cgi.ebay.com/ebaymotors/86-92...s#ht_623wt_722
Old 08-09-2010, 06:28 PM   #12
well ill be..
looks ugly tho
Old 08-10-2010, 01:36 AM   #13
Doesn't look nearly as robust as the one I've seen.... No cross member for rigidity, steel frame vs aluminum or 100% CF = heavier than it needs to be noodle (still better than having the top off, but I'll pass).
From the top it lookas a little thick... you sure they didn't just laminate a stock roof panel?
+1 for posting that!
Old 08-10-2010, 01:59 AM   #14
speedfiend
speedfiend's Avatar
speedfiend is on a distinguished road
Putting some aluminum bracing should be easy enough if you have the materials.
I am going to ask them how much they weigh and if any
structural framing is or can be done since they build individually.
I'll post their reply when I get it...
88 N/A targa, 5 speed, tint, thumpin' tunes, APEXi & KYB's, tweaked AFM, Hayden fan...
5 Favorite yodas I've owned, I am a believer!
85 Supra 5 speed, tint, sunroof
77 Celica GT, 20R, 5 speed, tint, cam, header, tweaked Mikuni S/Ds, K&N
91 DX & 99 LE Camrys, for when I did the family thing
86 1 Ton P/U, 22RE, SR-5 speed, tint, buckets, 500w stereo, header, alloys, tweaked AFM, K&N
86 4x4, 22RE 5-speed, tint, 4" lift, cam, header, tweaked AFM, K&N, bored .040
500 character limit...
speedfiend is offline   Reply With Quote
Old 08-10-2010, 02:31 AM   #15
Supra Saiyan
Supra Saiyan's Avatar
American Carbonfiber and Fiberglass
Ya I would like to hear their reply. On a black painted supra. I think this would be very nice looking.. I will FOR SURE be picking one up!
Old 08-10-2010, 02:34 AM   #16
Supra Saiyan
Not to change the subject in my own post but I also found this CB fiber guy from the same company..
http://cgi.ebay.com/ebaymotors/86-92...Q5fAccessories
Old 08-10-2010, 02:41 AM   #17
speedfiend
speedfiend's Avatar
Sweet! I overlooked that in their store, I think I'll have one of those...
Old 08-10-2010, 11:16 PM   #18
speedfiend
speedfiend's Avatar
Here's the message I sent and his reply...
Dear realcarbonfiber1,
I like the looks of the top you are offering and wanted to see if there was any internal bracing to help add rigidity, there are body flex issues with these cars when topless.
Also, I must have been looking in the wrong place but how much do your CF roofs weigh?
Thanks for your time...
David
- speedfiend
Dear speedfiend,
Hello I have not done any testing about performance, I would not
expect it to hold as well as stock, ours weight about 8 lbs, Thanks
- realcarbonfiber1
Old 08-10-2010, 11:24 PM   #19
ianstaley
ianstaley's Avatar
ianstaley is on a distinguished road
Hi guy's this is from the UK, I bought my targa toped MK3 In Germany TAX free, and I still have it here in England, I once had the idea to lighten the roof, over here it was made of thin steel, in the UK the targa top wasn't sold other than a persoonal import vehicle. I had had the car for a year when I went to work for Toyota in Holland as a freelancer for a while, I got into some heavy talks with Supra specalits engineers there at the time over weight reduction. There answer was that the removable roof constituted about 60% of the strength of the car, which is why the don't recomend exceeding 100 MPH unless you have strut bars, front and rear. As an alternative they did sugest that the roof coul be cut and fitted with a sunfoof, this they said (I didn't do it so basicly dont know if it was true or not) that the sun roof aftermarket would shave a few pounds off the roof but because of the way they were fitted then it would stiffen the roof too even if the glass was removed? Ian
Bored old git that loves his toyota's I have two one a Supra MK3 with a targa top the other is a brit Camry V6.
ianstaley is offline   Reply With Quote
Old 08-11-2010, 06:00 AM   #20
Supra Saiyan
Originally Posted by ianstaley View Post
I got into some heavy talks with Supra specalits engineers there at the time over weight reduction. There answer was that the removable roof constituted about 60% of the strength of the car, which is why the don't recommend exceeding 100 MPH unless you have strut bars, front and rear. As an alternative they did suggest that the roof could be cut and fitted with a sunroof, this they said (I didn't do it so basicly dont know if it was true or not) that the sun roof aftermarket would shave a few pounds off the roof but because of the way they were fitted then it would stiffen the roof too even if the glass was removed? Ian
You nearly shattered my hopes and dreams with that one.. 60% is a lot! However, I'm going against the weather man (Toyota mechanic) on this one. I'll get the umbrella but I won't wear the rain boots (Get front/rear struts). I just gotta have that carbon fiber roof (FOR ONLY $200)! It will go perfectly with my black mk3 project car..
Sometimes, weather men.. Are wrong! If it where a weather woman.. I would probably listen.. Well, at least "Watch".
