Old 08-04-2010, 07:47 PM   #1
ynnek
ynnek is on a distinguished road
Question TEMS Lights
All 3 indicator lights light up if I turn on my head lights & stay on until I turn off the head lights. The kicker is, if I turn on my lights first, then crank my car, the TEMS selection buttons & dash indicator light funtion properly. Any help on this subject would be greatly appricated.
ynnek is offline   Reply With Quote
Old 08-04-2010, 08:31 PM   #2
lol thats odd.
heres the trouble shooting guide for tems
http://www.cygnusx1.net/Supra/Librar...aspx?S=FA&P=30
Old 08-05-2010, 01:42 AM   #3
Very odd indeed. Is there any aftermarket interior lighting installed? EL gauged in particular....?
Confusing speculative, not completely thought out banter to follow:
The two circuits aren't connected at all. There is no illum/dim integration for this display (one of the only lighted circuits like this in the MKIII, the only other being the light switch indicator).
I can't find the blue TEMS display I've got somewhere around here for reference, but I believe the black wire chould be ground full time and the red, blue and green wires positive only depending on the TEMS controller's response. Which leaves us two possibilities to explore: The TEMS is active full time when the three are lit up (this is unlikely as ALL three conductors would have to be shorted across a positive signal) OR there's a bridged wire in the cluster or harness. Are you sure the TEMS isn't going full firm when the three lights light up? If so the bridge would be at one of the signal input lines (SPD, SS1, SS2 or VS).
http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=115
Sorry if this is confusing.... in short, there's no easy way for this to be occuring, but the more likely of the unlikely is that one of the input signal lines is shorted to a positive.... wierd.
Old 08-05-2010, 01:45 AM   #4
Just to make sure there's no short across the cluster illumination wiring, unplug the dimmer and pull the gauge out as far as you can while it's still plugged in. Test for continuity across the white/green stripe wire at the dimmer harness and each of the four wires from the TEMS display.
Old 08-05-2010, 12:18 PM   #5
ynnek
Default Thanks for the replies
I will get around to checking these a bit later, as is has been over 100 degrees for several days here in Memphis. Once I get home from work I just want to sit in the AC for a while.
Old 10-07-2010, 01:16 PM   #6
ynnek
Default Tail Light problem
was coinciding with this problem. I replaced all of my bulbs, & tightened all of the grounding screws & the problem went away. I did not think these two systems had anything to do with one another. Oh well, everything is ok now.
Tail lights and side bumber lights. Peter M Exterior , Interior, and Detailing 1 06-22-2010 07:23 PM
Dash lights interior door lights and tail lights not working TripleC MKIII Supra 10 03-16-2010 12:48 PM
LF: Lightbulbs guide lamw001 MKIV Supra 2 09-18-2008 02:23 PM
TEMS....Function mrnickleye MKIII FAQ 3 10-29-2007 05:07 PM
